1. Samnvb's Avatar
    I have added timely as my alarm and it will not work. I charge my phone when I go to sleep and in the morning I get a message "phone is starting" and no alarm until after log in... Please help thank you in advance
    12-05-2019 09:57 PM
  2. mustang7757's Avatar
    Hi , Welcome!
    You have the phone set to automatically restart everyday?
    12-05-2019 10:06 PM
  3. Rukbat's Avatar
    Sounds like a bad battery, if it won't hold enough charge on standby for one night.
    12-05-2019 10:17 PM
  4. CellPhOneAGe's Avatar
    It seems the battery issue! It's better to take it to the after-sales centre for testing.
    12-05-2019 10:36 PM
  5. VidJunky's Avatar
    While the previous comments seem to be blaming the battery, if I'm reading your thread correctly, it sounds like you are charging it overnight. In order to really help you we will need some answers and more details.
    First what device do you have?
    Do you have any kind of auto restart or power off timer set? On my Samsung the auto restart can be set for as often as I want I believe but I only have it set for once a week. Have you checked this or for this setting?
    If the restarts are not intentional or accidentally set to be intentional, are you telling us that your device turns itself off even when on the charger? If this is what is happening the alarm is the least of your issues. This is a far bigger one that needs to be addressed before we go any farther. It could be the battery, the charger, the charging cable, the port, any number of things.
    Now it's your turn, offer some input to get better advice...
    mustang7757 and B. Diddy like this.
    12-05-2019 11:29 PM
  6. B. Diddy's Avatar
    Duplicate threads merged. VidJunky brings up important points -- I was also wondering if there is an auto-restart option that's turned on.
    VidJunky likes this.
    12-06-2019 01:16 AM
  7. j_hansen's Avatar
    If it is not because you have auto restart enabled then maybe contact the app developer to see if it is supposed to be compatible with your phone...
    Or even simpler, use the clock/alarm app Samsung put on your phone
    12-06-2019 04:04 AM
  8. VidJunky's Avatar
    You know I was thinking something similar, we're not sure what device they have and may never know as there's no reply, but what could an alarm app bring to the table I wondered, then went and checked it out. It's just pretty colors and a couple of faces, so yeah literally just get over it and use the stock app that works or try something else. There's tons of free apps at the Play Store.
    Rukbat likes this.
    12-06-2019 05:08 AM
  9. Samsmome's Avatar
    Hello all!
    I have the unlocked note 10+ running Android Beta 10. I too use the timely app. I've had no issues with it. I don't have my phone set to auto restart. So I really can't see why they're having a problem.
    12-06-2019 05:41 AM
  10. B. Diddy's Avatar
    Timely is a bit odd in that the developer Bitspin was acquired by Google back in 2014, and yet the app is still available in the Play Store under the Bitspin name, and hasn't been either changed to a Google product or simply killed outright (after incorporating whatever Google liked about it into the stock Clock app).
    It also hasn't been updated in more than a year, so I wonder if it's just been abandoned ...
    12-06-2019 11:45 AM
  11. Rukbat's Avatar
    About the only thing it has that the stock alarm doesn't is cloud integration so all your devices have the same alarms in them. Something a Google developer familiar with their cloud access could probably add in 5 minutes (developing and testing, both).
    And Bitspin is bitspin.ch, so I wonder.
    12-07-2019 04:54 PM
  12. B. Diddy's Avatar
    For further murkiness, the physical address is listed as Switzerland: Timely Alarm Clock - About
    12-07-2019 06:04 PM
  1. Alarm app won't turn off
    By Casey Cheung in forum Samsung Galaxy Watch
    Last Post: 12-12-2019, 01:47 PM
  2. Nexus 5 Time Capsule
    By Jeremy8000 in forum Google Nexus 5
    Last Post: 12-06-2019, 11:47 AM
  3. My apps keep closing and I’m not getting time to txt as it shut?
    Last Post: 12-05-2019, 05:11 PM
  4. My S6 Apps keep closing down after being opened for not even 2 seconds.
    Last Post: 12-05-2019, 03:51 PM
  5. Replies: 1
    Last Post: 12-05-2019, 11:46 AM
