My cell strength is horrible but it's always been horrible and I was still getting 8hrs of sotIt'd be helpful to see what the cell signal strength is like throughout the day, since poor cell signal can eat up battery. Use GSam Battery Monitor to get a better idea of the signal strength.
I used to get 8hrs of screen on time...now a dramatic drop..why? What can I do?//uploads.tapatalk-cdn.com/20191206/d9c9b56f141d3b0b1bd97f2c682b3eb0.jpg
I only get 4 hours to 6 hours max sot...
What screen brightness?
Location on always?
I can't believe you're actually questioning if it's been in the sun? Sure let's move the sun lol. No problem.
Did this start from a recent update ? Have you download any new apps ? Also you tried clearing cache in recovery ?I used to get 8hrs of screen on time...now a dramatic drop..why? What can I do?//uploads.tapatalk-cdn.com/20191206/d9c9b56f141d3b0b1bd97f2c682b3eb0.jpg
Location on always?
Auto brightness. Location on when using Google Maps...
I use auto brightness as well but the phone will override that if used outside in bright light, location is a battery zapper as well but not as bad as it was just a few years ago.
Cell signal has nothing to do with battery drain.
It's actually "as the phone increases its transmitting power, because a weak signal at the phone means a weak signal at the tower.poor cell signal can cause increased battery use as the phone tries to latch onto a weak signal
And because having the phone n the sun, automatic brightness or not, means that the screen is going to be turned up, one way or another (automatically or manually.This is not that outlandish a question. If a phone has been in direct sunlight for a while (and therefore heating up), that could impact the battery life as well. This can especially be seen when the phone is in a car mount on the windshield on a hot sunny day.
Exactly.. extreme temperatures will wear battery down no questionsAre you saying that poor cell signal in general doesn't contribute to battery drain, or that in your situation, you're sure the cell signal isn't a problem? It's clear that poor cell signal can cause increased battery use as the phone tries to latch onto a weak signal, so I would dispute a claim that poor cell signal has nothing to do with battery drain.
Cell signal has everything to do with battery drain.Cell signal has nothing to do with battery drain. And even so it can't eat up that much. Samsung phones are known to have random battery drain for weeks at a time. YouTube it.
Ok but how many people leave there phone in direct sun light for hours on end? Not many? Cell signal doesn't have a major impact. Samsung phones are known for random draining as I've personally experienced it myself. There's a YouTube video on it. YouTube it.It's actually "as the phone increases its transmitting power, because a weak signal at the phone means a weak signal at the tower.
And 1/4 of the OP's battery use is the screen, so that's probably a large part of the problem.
