12-12-2019 02:42 PM
27 12
tools
  1. Stealthieone's Avatar
    I used to get 8hrs of screen on time...now a dramatic drop..why? What can I do?
    12-06-2019 05:47 PM
  2. B. Diddy's Avatar
    It'd be helpful to see what the cell signal strength is like throughout the day, since poor cell signal can eat up battery. Use GSam Battery Monitor to get a better idea of the signal strength.
    12-06-2019 11:00 PM
  3. j_hansen's Avatar
    Have you used it outside in sunshine more or manually upped the brightness
    gendo667 likes this.
    12-07-2019 03:45 AM
  4. Stealthieone's Avatar
    My cell strength is horrible but it's always been horrible and I was still getting 8hrs of sot
    12-07-2019 07:08 AM
  5. B. Diddy's Avatar
    I guess one question would be how horrible? If the signal strength was bad before, but has now become markedly worse, that could still be a reason. The signal bar icon on the status bar isn't the most accurate. That's why an app like GSam can be helpful, since it can report the cell signal strength with somewhat more granularity. (Then again, it might not help that much, since we wouldn't be able to compare it with a measurement taken before the problem started to happen.)
    12-07-2019 06:08 PM
  6. Hermes Hidayat's Avatar
    I used to get 8hrs of screen on time...now a dramatic drop..why? What can I do?https://uploads.tapatalk-cdn.com/201...2c682b3eb0.jpg
    I only get 4 hours to 6 hours max sot...
    12-07-2019 10:20 PM
  7. j_hansen's Avatar
    What screen brightness?
    Location on always?
    12-08-2019 06:03 AM
  8. mlbyanks11's Avatar
    Cell signal has nothing to do with battery drain. And even so it can't eat up that much. Samsung phones are known to have random battery drain for weeks at a time. YouTube it.
    12-08-2019 08:43 AM
  9. adegbenroagoro's Avatar
    Location on always?
    So many factors involved. I use mine at 1440p, maximum brightness with location and Bluetooth always on. Either WiFi or mobile data is on depending on my location. I get 7-9 hours SOT.
    12-08-2019 08:55 AM
  10. Xxwabbit's Avatar
    Cell signal is definitely my problem. I live on the outskirts of city. My property sits in a little depression. When I go into shop, phone goes between 3g and 1x with no wifi and I have to step outside to call. If I stay in shop 12 hours, I will have to top off battery and that's hardly any sot. However, my house sits on a little bluff on same property and I get 4g w/2 bars and wifi, but battery can last 2 days.
    12-08-2019 09:20 AM
  11. j_hansen's Avatar
    I can't believe you're actually questioning if it's been in the sun? Sure let's move the sun lol. No problem.
    Not everyone lives in a very sunny place or use their phone outside most of the day.
    I get nearly double SoT when here in cloudy grey Ireland compared to bright sunny Spain
    12-08-2019 09:22 AM
  12. mustang7757's Avatar
    Did this start from a recent update ? Have you download any new apps ? Also you tried clearing cache in recovery ?
    12-08-2019 09:23 AM
  13. Hermes Hidayat's Avatar
    Location on always?
    Auto brightness. Location on when using Google Maps...
    12-08-2019 09:40 AM
  14. j_hansen's Avatar
    I use auto brightness as well but the phone will override that if used outside in bright light, location is a battery zapper as well but not as bad as it was just a few years ago.
    12-08-2019 11:06 AM
  15. Hermes Hidayat's Avatar
    Im sure its because of my weak cellular signal. If im at home the entire day and on wifi(airplane mode but wifi on) the battery could give 7 hours to 9 hours SOT...
    Laura Knotek and Relletti like this.
    12-08-2019 11:08 AM
  16. B. Diddy's Avatar
    Are you saying that poor cell signal in general doesn't contribute to battery drain, or that in your situation, you're sure the cell signal isn't a problem? It's clear that poor cell signal can cause increased battery use as the phone tries to latch onto a weak signal, so I would dispute a claim that poor cell signal has nothing to do with battery drain.
    This is not that outlandish a question. If a phone has been in direct sunlight for a while (and therefore heating up), that could impact the battery life as well. This can especially be seen when the phone is in a car mount on the windshield on a hot sunny day.
    mustang7757 and Laura Knotek like this.
    12-09-2019 12:05 AM
  17. Rukbat's Avatar
    It's actually "as the phone increases its transmitting power, because a weak signal at the phone means a weak signal at the tower.
    And because having the phone n the sun, automatic brightness or not, means that the screen is going to be turned up, one way or another (automatically or manually.
    And 1/4 of the OP's battery use is the screen, so that's probably a large part of the problem.
    12-09-2019 12:16 AM
  18. mustang7757's Avatar
    Exactly.. extreme temperatures will wear battery down no questions
    B. Diddy likes this.
    12-09-2019 12:23 AM
  19. Mike Dee's Avatar
    Cell signal has everything to do with battery drain.
    12-09-2019 08:43 AM
  20. mlbyanks11's Avatar
    Ok but how many people leave there phone in direct sun light for hours on end? Not many? Cell signal doesn't have a major impact. Samsung phones are known for random draining as I've personally experienced it myself. There's a YouTube video on it. YouTube it.
    12-12-2019 10:06 AM
  21. B. Diddy's Avatar
    Cell signal can have a major impact. We should let that issue rest. You don't have to believe it, but it's a fact.
    I don't dispute that some Samsung phones can have random battery drain issues -- but really, any phone can. It could be due to many reasons, including firmware glitches, hardware defects, a bad batch of batteries, poorly coded apps, etc.
    12-12-2019 01:54 PM
  22. j_hansen's Avatar
    I think if anyone is suffering abnormal battery drain issues with their phone, they should send it in for warranty repair or replacement, whether it is a Samsung or any other phone.
    12-12-2019 02:06 PM
  23. mustang7757's Avatar
    That's after all troubleshooting steps is tried first , what if the same situation happens with the replacement phone .
    12-12-2019 02:12 PM
  24. j_hansen's Avatar
    It then means that the person owning the phone is a thick plank :-)
    Sorry, my point was more that if people are 100% convinced it's the phone then there is no point arguing about it on a web forum, send it in and have Samsung test it for faults, not everyone feels comfortable doing troubleshooting themselves
    mustang7757 likes this.
    12-12-2019 02:21 PM
  25. mustang7757's Avatar
    I agree , if they don't feel comfortable themselves have Carrier or the phone manufacturer try help . But you understand what I'm trying to say .
    12-12-2019 02:25 PM
27 12
  1. people looking to make a profit **** me off
    By gizzyman in forum Samsung Galaxy Tab S6
    Last Post: 12-31-2019, 01:05 AM
  2. how to update system
    Last Post: 12-07-2019, 07:16 PM
  3. I can't make my phone brighten.
    Last Post: 12-07-2019, 07:12 AM
  4. How to fix phone data stuck on edge when it is restarted
    Last Post: 12-06-2019, 04:34 PM
  5. Why doesnt my phone screen want to go on but its on
    Last Post: 12-06-2019, 12:00 PM
