1. Super Dave426's Avatar
    I really miss the LED notification on the device, such a quick way of noticing the charge was full or have a message.
    12-14-2019 06:29 PM
  2. Lepa79's Avatar
    Give this a try. Best out there. Uses the ring around the front camera for LED notifications.
    https://play.google.com/store/apps/d...lwaysondisplay
    12-14-2019 07:21 PM
  3. kevinpleasants's Avatar
    Try AodNotify or Led Me Know
    mustang7757 likes this.
    12-14-2019 08:03 PM
  4. Hermes Hidayat's Avatar
    Well...i just downloaded it. Got the paid version. Very good. I recommend it.
    Lepa79 likes this.
    12-15-2019 05:40 AM
  5. Knightmayre90's Avatar
    I just use the AOD to see all my notifications.
    runfar262 likes this.
    12-15-2019 06:54 AM
  6. Hermes Hidayat's Avatar
    AOD only shows 3 icons and +2 or +3 or +4 and so on...
    12-15-2019 07:14 AM
  7. chazglenn3's Avatar
    LED Me Know is a great replacement for the lack of an LED notification light.
    kevinpleasants likes this.
    12-15-2019 10:32 PM
  8. sweetypie31's Avatar
    The only time I miss the led is for charging , but other than that I hardly notice it's gone. *Shrugs*
    glad that there's alternatives for those who miss it though.
    adegbenroagoro and cass_m like this.
    12-16-2019 10:21 AM
  9. Super Dave426's Avatar
    The charging is the most missed, it just isn't easy to see on the AOD, or if I charge the phone when it's off. I'm definitely going to check out the recommendations, thanks.
    12-16-2019 10:26 AM
  10. Fast-T's Avatar
    The little battery symbol turns green once fully charged. Pretty easy to see
    12-16-2019 12:20 PM
  11. Super Dave426's Avatar
    Not if I don't have my glasses on, that are only needed to read.
    12-16-2019 02:29 PM
  12. Rukbat's Avatar
    I use GSam Battery Monitor for that - it plays a notification when the battery gets too low and another one when it gets to the charge point I want (98%). Or, if the phone is rooted, you can use Battery Charge Limit and it will start and stop where you set it to - no need to even look at the phone in either case.
    sweetypie31 likes this.
    12-16-2019 03:56 PM
  13. runfar262's Avatar
    At first I missed it but now I just use AOD.
    12-16-2019 08:39 PM
  14. Fast-T's Avatar
    Just look for a "green thing". That's what I am doing . I know your pain! It's always at the bottom, away from other notifications
    12-17-2019 02:23 AM
  15. Fast-T's Avatar
    See here ... not green yet, but I don't want to stay up for another two hours
    Super Dave426 likes this.
    12-17-2019 02:24 AM
  16. Forgewizard's Avatar
    Mine doesn't turn green. Just shows as full and 100% but is white.
    12-18-2019 02:26 AM
  17. Philipmom's Avatar
    You can disable the battery notification in one ui 2.0. Which shouldn't be too far off.
    12-18-2019 08:25 AM
  18. Super Dave426's Avatar
    Mine turns a shade of green that doesn't show well.
    12-18-2019 02:18 PM
  19. Fast-T's Avatar
    Mine turns as green as it can get.
    12-19-2019 09:55 AM
  20. kirksucks's Avatar
    Installed. Haven't noticed anything happening with the camera hole
    12-26-2019 05:20 PM
  21. Super Dave426's Avatar
    Giving this one a try now, should come in handy while driving in the dark.
    12-26-2019 06:53 PM
  22. Lepa79's Avatar
    I used the app to mainly turn on AOD when I have notifications from apps that I care about (instead of AOD on all the time) and as soon as I read the notifications or swipe them away, AOD will turn back off. Perfect to what I need.
    That said, using camera ring as LED notification is also an option in the setting. Didn't use that though.
    12-26-2019 08:55 PM
  1. security folder individual app notification sound.
    Last Post: 12-16-2019, 03:57 PM
  2. Double message notifications?
    By garethrdwilliams in forum Huawei Mate 20 & Huawei Mate 20 Pro
    Last Post: 12-16-2019, 09:27 AM
  3. S10 heads up Textra notifications
    By TNRonin in forum Ask a Question
    Last Post: 12-14-2019, 08:26 PM
  4. Why do I keep getting Voice Mail notifications?
    Last Post: 12-14-2019, 07:52 PM
  5. Samsung Note 3 notification error solution
    By ananomoose in forum Samsung Galaxy Note 3
    Last Post: 12-14-2019, 11:55 AM
