Phone not ringing on some calls
Recently I've noticed that on some incoming calls my phone doesn't ring at all and sends the caller to my voicemail and other times I see the incoming call but there's no notification sound...other times it works just fine. Anyone else experiencing this or know how to fix?
Re: Phone not ringing on some calls
Do you use DND ? Have you noticed this after a software update or recent app installed?
Never use DND...never noticed how long after the last update before noticing the issue. I'll have to look at any recent apps but none I can think of.
Well , we can start by clearing data,cache, force stop the phone app see any glitches.
I will give those a shot, thanks!
