1. missionsparta's Avatar
    Anyone notice that after the Android 10 and UI2. 0 update on the Samsung devices, that the People Edge no longer calls the default contact number, but the top number on the list in your contact? Ridiculous. So I have to manually remove all the numbers in a contact and manually out them back in and reorder them so that the mobile number is the top number, so it will call mobile when I select that person in the edge app. This is nuts.
    12-26-2019 10:31 PM
  2. adegbenroagoro's Avatar
    I just checked. Mine is working fine.
    12-27-2019 06:39 AM
  3. missionsparta's Avatar
    Test something for me. Set the default number to one of your edge contacts to something other than the first/top number and try calling them from the edge panel again. Does it call the top number or the default number you set further down the list?
    12-31-2019 02:31 PM
  4. adegbenroagoro's Avatar
    I just did as you requested. It still worked as programmed. It called the number further down the list. Have you cleared the cache for EDGE APPS ?
    12-31-2019 05:20 PM
  5. missionsparta's Avatar
    I'll try.
    12-31-2019 10:10 PM
  6. missionsparta's Avatar
    How do I do that?
    01-13-2020 05:24 PM
  7. adegbenroagoro's Avatar
    Go to SETTINGS in your app drawer (or drag down your notification panel and click on the wheel icon in upper right corner). Scroll down to APPS. Tap on it and scroll down to EDGE APPS. Tap on that and then on STORAGE. You'll find CLEAR CACHE at the bottom and right of the screen.
    01-14-2020 12:03 PM
  8. adegbenroagoro's Avatar
    I'm sorry. I sent 4 screen shots but somehow it showed up differently in the posted article.
    01-14-2020 12:08 PM
  9. missionsparta's Avatar
    Ahh.. I knew how to do it but forgot about system app setting. I just have Edge Screen listed there. I assume that's it?
    01-15-2020 08:09 PM
  10. adegbenroagoro's Avatar
    Most likely.
    01-16-2020 04:45 PM
  1. Android 10 with Android Auto Issues
    By MysticalDreams in forum Android Auto
    Last Post: 01-02-2020, 11:31 AM
  2. Lock screen wallpaper colour issue post Android 10 update.
    Last Post: 12-29-2019, 02:58 PM
  3. This thing after latest update from AT&T
    By AmyC76 in forum Samsung Galaxy S10 & S10+
    Last Post: 12-27-2019, 04:13 AM
  4. How do I fix a PRL Internal Error(407) on Samsung Galaxy Note 5?
    Last Post: 12-27-2019, 03:47 AM
  5. How do i use my key board on my ONN 10.1 Android tablet
    Last Post: 12-26-2019, 08:53 PM
