1. novice97's Avatar
    Hi! Ever since I updated to Android 10 on my AT&T Note 10 + I can no longer single tap to answer a phone call. I used to have this enabled under "Accessibility " but it is no longer there. Does anyone know how to enable this now? Thanks!
    01-05-2020 09:46 AM
  2. j_hansen's Avatar
    Is it not under assistant menu?
    Single tap to swipe
    01-05-2020 11:08 AM
  3. novice97's Avatar
    Not on my phone.
    01-09-2020 12:26 PM
  4. mustang7757's Avatar
    Try going to settings>general managment>reset>reset accessibility and check again
    01-09-2020 12:27 PM
  5. j_hansen's Avatar
    Not on my phone.
    Mine seems to have disappeared after update to android 10, have it set to answer using volume up instead which is fine for me
    01-09-2020 01:33 PM
  6. novice97's Avatar
    Thank you all! I was available to find it again under the assistant menu.
    mustang7757 likes this.
    01-10-2020 07:26 PM
  7. mustang7757's Avatar
    01-10-2020 09:36 PM
  1. Replies: 6
    Last Post: 01-16-2020, 06:05 AM
  2. I am editing the "notes" under Contacts directly on my phone.
    Last Post: 01-06-2020, 03:31 PM
  3. Replies: 8
    Last Post: 01-06-2020, 01:30 PM
  4. Call failed number not registered with watsapp
    By Android Central Question in forum Android Apps
    Last Post: 01-05-2020, 01:36 PM
  5. Factory reset from within phone
    By cryptofish in forum General Help and How To
    Last Post: 01-05-2020, 12:59 PM
