Note 10 plus: Play notification sounds on phone speaker instead of bluetooth device
Tim-ANC
Trusted Member
Apr 22, 2015
29
I have Jay Bird blue tooth buds connected all day to use for calls. I want my notification sounds to play over the phone speaker instead of through the buds but I can't find the setting to change this.
mustang7757
Super Moderator
Moderator
Feb 6, 2017
91,475
6,090
113
Do you see a option in bluthooth under. Your Bluetooth device a option to toggle just calls
Tim-ANC
Trusted Member
Apr 22, 2015
29
Wow, you're fast brah! I see toggles to use for calls and audio. I suppose I should de-select the audio option.
Cy3berOdyssey
