1. Tim-ANC's Avatar
    I have Jay Bird blue tooth buds connected all day to use for calls. I want my notification sounds to play over the phone speaker instead of through the buds but I can't find the setting to change this.
    01-07-2020 07:56 PM
  2. mustang7757's Avatar
    Do you see a option in bluthooth under. Your Bluetooth device a option to toggle just calls
    01-07-2020 08:05 PM
  3. Tim-ANC's Avatar
    Wow, you're fast brah! I see toggles to use for calls and audio. I suppose I should de-select the audio option.
    mustang7757 likes this.
    01-07-2020 08:08 PM
  4. mustang7757's Avatar
    Lol ..yeah try that
    Tim-ANC likes this.
    01-07-2020 08:24 PM
  5. Tim-ANC's Avatar
    Lol ..yeah try that
    Thanks. Will report how it is tomorrow
    01-07-2020 10:46 PM
  6. mustang7757's Avatar
    Ok ..your welcome!
    01-07-2020 10:55 PM
  7. Tim-ANC's Avatar
    Works. Notifications sounds play over the phone speaker now with the jaybirds connected to bluetooth
    01-12-2020 02:41 PM
  8. mustang7757's Avatar
    That's great
    Tim-ANC likes this.
    01-12-2020 02:44 PM
  1. Google Play Store no installing
    Last Post: 01-07-2020, 10:23 PM
  2. Replies: 3
    Last Post: 01-07-2020, 08:36 PM
  3. How to turn on my url
    Last Post: 01-07-2020, 08:01 PM
  4. My phone is asking me for puk every sim i try
    Last Post: 01-07-2020, 06:09 PM
  5. Extremly hot phone, broken sd card
    By bratley0 in forum Samsung Galaxy Core Prime
    Last Post: 01-07-2020, 04:59 PM
