1. MikeS1971's Avatar
    Since installing the Android 10 update on my Note+ and my fiancée's Note 10+, we can no longer place calls or send/receive texts while Wi-Fi is turned on. Also while wifi is on, calls place to us go directly to voice mail.
    As soon as wifi is turned off, we get a flood of texts and voice mail notifications.
    Anyone else have this issue?
    01-08-2020 11:26 AM
  2. mustang7757's Avatar
    01-08-2020 11:28 AM
  3. B. Diddy's Avatar
    Was this an official update over-the-air, or did you manually install it from a website?
    01-08-2020 11:39 AM
  4. MikeS1971's Avatar
    I'm on Verizon.
    It is the official update that came up on the phone.
    01-08-2020 11:46 AM
  5. B. Diddy's Avatar
    Have you asked Verizon about it? Also, try turning off Wi-fi Calling and see if calls and texts work. If it does, then see if the problem comes back after turning it back on. If the problem does return, you might try the Reset Network Settings option.
    01-08-2020 11:47 AM
  6. mustang7757's Avatar
    If those don't work I have few other steps to try .
    01-08-2020 11:51 AM
  1. How can I sort my quick responses for text messaging?
    By prb456 in forum General Help and How To
    Last Post: 03-28-2020, 02:02 PM
  2. I need to put Boost Zone on my phone. It is not in my apps.
    Last Post: 02-09-2020, 01:09 AM
  3. How can I stop this notification from showing all the time?
    By Lucy Davies in forum Huawei P20 & P20 Pro
    Last Post: 01-09-2020, 05:41 AM
  4. Why Can I NOT remove the wrench symbol nor the triangle symbol on my Galaxy S9
    Last Post: 01-08-2020, 11:18 AM
  5. Dex, Phone Screen Timeout and Android 10
    By JoeInCT in forum Samsung DeX
    Last Post: 01-08-2020, 09:52 AM
