    Hey guys,
    Having an issue with my Galaxy Note 10 (Smaller Version) where the same wallpaper is more vibrant and colourful on the lock screen, and as I unlock it the same wallpaper on the home screen gets muted in colour and more dull.
    This is quite odd and I've never experienced it before neither can I fix it with any display settings (ie. Natural > Vibrant). Also, blue light filter is switched off, so is adaptive brightness. Any ideas? Hardware or Software issue? It's currently on Android 10 and I've noticed a few bugs here and there as well.
    01-15-2020 04:48 AM
  2. Hermes Hidayat's Avatar
    Hey guys,
    Do you use face unlock? If so, is the brigthen screen turned on?
    01-15-2020 05:39 AM
  3. Mike_Luchia's Avatar
    Hey guys,
    If you're using One UI 2.0 Android 10 and have dark mode turned on, it also turns down the brightness of the home screen to save on battery as well.
    kevinpleasants likes this.
    01-15-2020 09:12 AM
  4. mustang7757's Avatar
    'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    01-15-2020 09:56 AM
  5. FooBo's Avatar
    OP here.
    I've done research and yes having dark mode on with "Apply to Wallpaper" will also darken the wallpaper. However that isn't my issue, it doesn't darken the home screen wallpaper it just dulls and mutes the colours compared to the same paper on the lockscreen. Tried replicating on a friend's Note 10+ and is the same issue. Also noticed it only happens to some wallpapers with more colourful palletes. Perhaps a software thing?
    01-15-2020 06:23 PM
  6. mustang7757's Avatar
    OP here.
    Hi,welcome!
    Have you tried stock wallpaper if same issue? Possible could be the wallpaper your using
    01-15-2020 06:52 PM
  7. FooBo's Avatar
    Hi,welcome!
    Thanks!! Stock wallpapers are fine.. I suppose it's only with certain walloapers.. Very odd and also annoying, mutes colours quite a bit starts looking like a low quality display
    Guess nothing can be done, appreciate the input guys.
    mustang7757 likes this.
    01-15-2020 07:00 PM
  8. mustang7757's Avatar
    Your welcome !
    Zedge is a good place for wallpapers
    ROE_HUNTER likes this.
    01-15-2020 07:06 PM
  1. Official S20 wallpapers available
    By mustang7757 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 02-20-2020, 04:15 PM
  2. Strange symbol om screen
    By Woiwoi20 in forum Huawei Mate 20 Lite
    Last Post: 02-14-2020, 01:34 AM
  3. Pixel 4xl ENABLE SCREEN RECORD
    By mustang7757 in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 01-19-2020, 11:55 AM
  4. Screen lights up every time when text is recieved
    By Oscar Maradiaga in forum Samsung Galaxy S10 & S10+
    Last Post: 01-15-2020, 12:06 PM
  5. My Samsung s5 phone is not locking with the fingerprint option
    By Aziel August in forum Samsung Galaxy S5
    Last Post: 01-14-2020, 11:10 PM
