S20 - a few questions
anon(10621852)
89
Just wondering if anyone might know ... I know the S20 isn't out yet, but maybe someone will know:
1) Will Edge Lighting be present on the S20 or do you think that'll be gone because the edge is not as curved as previous models?
2) Wondering if you get the "Hey Google" always listening feature? In other words, can you say "Hey Google" from across the room (hands free) and it's available?
Thanks!
Thanks!
2 will definitely be there as Google Assistant isn't going anywhere. 1 is an interesting point that I hadn't really thought about, but I doubt it's going anywhere.
If they did remove edge lighting then im sure there would be plenty 3rd party apps to choose from anyway
heitezy
