1. Borgie's Avatar
    Take them out of the ears and throw them in the case to charge up. They can only go in one way so you shut the case and let it do its thing.
    Come back later and they haven't charged, sometimes they do. I put in a small piece of thin phone tape in the top cavities and this seems to have taken care of the issue, but i shouldn't have to do that. Put them in, close the cover, and they should charge.
    Samsung says its my fault for not putting them in perfectly. WTF, they can only go in one way.
    02-16-2020 12:04 PM
  2. Mike Dee's Avatar
    The only thing I can suggest is make sure the cushions are all the way in and wipe the contacts. Mine light up before I close the lid I think, but I'll have to double check
    02-16-2020 12:07 PM
  3. msm0511's Avatar
    Are you using the tips that came with the Buds or aftermarket such as Comply? I've heard of that happening with Comply tips.
    02-16-2020 12:28 PM
  4. Borgie's Avatar
    Factory tips (large)
    02-16-2020 01:28 PM
  1. Is it possible to hide the UI on the stock camera app?
    Last Post: 04-13-2021, 11:35 PM
  2. Not updating
    By johnnie 65 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 02-18-2020, 05:58 PM
  3. Galaxy S7 random media volumes
    By HOWARD ROSENBLOOM in forum Ask a Question
    Last Post: 02-18-2020, 04:23 PM
  4. I've hard bricked my samsung galaxy s (SC-02B) Need help to fix it.
    By Victor Connor in forum Samsung Galaxy S
    Last Post: 02-16-2020, 02:56 PM
  5. Moto G4 dropped, screen not working!
    By Phil Ed in forum Moto G
    Last Post: 02-16-2020, 01:52 PM
