    Hi. Please share how you are cleaning your Note 10 to work it smoother or to empty some space?
    02-20-2020 01:53 PM
  2. mustang7757's Avatar
    Note 10 been smooth running phone but you can clear stuff in device care by tapping the optimized button once in awhile.
    'll leave a Link to register so you can communicate here as a guest account you can only post questions but can't reply.
    https://forums.androidcentral.com/sh...d.php?t=409154
    02-20-2020 01:55 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! I strongly recommend against using any 3rd party "phone cleaner" apps, since they often do things that are counterproductive, and they often come with sneaky ads and unwanted "features" (not to mention routing some of your data through shady servers).
    j_hansen likes this.
    02-20-2020 06:44 PM
  4. j_hansen's Avatar
    Back up important stuff, factory reset, install backup...
    A bit radical but you clean up/out :-)
    02-20-2020 07:18 PM
  5. dtones39's Avatar
    My opinion, unless you are trying clear up storage or troubleshooting an issue, there really isn't a need. You can turn on auto optimization in device care and schedule a reboot once a night and your note should run excellent.
    If you want to find and empty space, I use the Google files app. Easy to use and it will show you apps you don't use, junk files and duplicate files.
    02-20-2020 07:20 PM
  1. Android 10 for Verizon S9 now live!
    By Nicholas Stevens in forum Samsung Galaxy S9 & S9+
    Last Post: 02-28-2020, 01:18 PM
  2. Android 10 available in Australia Note 9
    By SteveSAPA in forum Samsung Galaxy Note 9
    Last Post: 02-27-2020, 11:44 PM
  3. Android 10 update screws Android Auto on the Note 9
    By brentj in forum Samsung Galaxy Note 9
    Last Post: 02-24-2020, 09:44 AM
  4. Note 3 Update
    By johnnyd33 in forum Samsung Galaxy Note 3
    Last Post: 02-20-2020, 06:04 PM
  5. S10 - Android 10 can't change notifications sounds
    By BaritoneGuy in forum Samsung Galaxy S10 & S10+
    Last Post: 02-20-2020, 04:22 AM
