1. donebrasko's Avatar
    I now have that popping up in my notification panel. Does anyone know how to get rid of it? It just started doing that. Messenger has been acting up also
    02-24-2020 06:06 AM
  2. msm0511's Avatar
    Do you mean Facebook Messenger? You could try uninstalling and reinstalling.
    02-24-2020 07:44 AM
  3. donebrasko's Avatar
    Yeah Facebook messenger. I'll try that.
    02-24-2020 08:41 AM
  4. donebrasko's Avatar
    Common sense prevailed.
    It worked
    02-25-2020 03:52 PM
  5. donebrasko's Avatar
    I was wrong... All the problems started back again.
    02-28-2020 10:29 PM
  6. donebrasko's Avatar
    Any other suggestions? Notifications no longer work. Chat heads didn't work either. I made sure that everything was on when I deleted the app and reinstalled it.
    03-01-2020 08:39 PM
  7. mustang7757's Avatar
    Can you post a screenshot what it says in notifications panel?
    03-01-2020 08:54 PM
  8. donebrasko's Avatar
    I cleared the cache and it started working again... now it's back to messing up again.Messenger is running?-screenshot_20200302-020739.jpeg
    03-02-2020 02:31 PM
  9. mustang7757's Avatar
    I cleared the cache and it started working again... now it's back to messing up again.Click image for larger version.
    If you tap for more information what does it say?
    03-02-2020 02:51 PM
  10. donebrasko's Avatar
    This is where it goesMessenger is running?-screenshot_20200302-161132_settings.jpegMessenger is running?-screenshot_20200302-161145_settings.jpeg
    03-02-2020 03:12 PM
  11. donebrasko's Avatar
    The problem that I am having:
    Chat heads doesn't pop up anymore... It's turned on.
    My notifications for just this app is a very slight vibration and that's it.
    If I pull the notification shade down I'll see the message.
    If I click on the message nothing happens. It doesn't take me to messenger
    I can't share pictures from another message.
    When I clear cache it works for a couple of minutes then it goes back to messing up
    Also when I am in messenger the new messages are highlighted as unread. When I open them it goes away but it turns right back to unread.
    03-02-2020 03:21 PM
  12. mustang7757's Avatar
    Thank you for the info, I'll try find more info on this ,there's no uninstall update otherwise I would suggest that , can try uninstall messenger and use messenger lite see how that goes might be a bug in regular messenger .
    03-02-2020 03:28 PM
  13. donebrasko's Avatar
    I'll try lite. I've already deleted and updated it.
    Maybe it's an app messing it up
    mustang7757 likes this.
    03-02-2020 03:40 PM
  14. mustang7757's Avatar
    Ok
    03-02-2020 03:54 PM
  15. msm0511's Avatar
    How long as it been happening? I don't have Messenger installed, but looked in the Play Store and noticed there was an update Feb. 10th. Could just be something FB screwed up with the most recent update and have to wait it out until they fix it.
    03-02-2020 05:26 PM
  16. donebrasko's Avatar
    I noticed it happening before I took the last update.
    03-02-2020 07:17 PM
  17. mustang7757's Avatar
    Have you tried lite yet see if any issues with that ?
    03-02-2020 09:06 PM
  18. donebrasko's Avatar
    No issues with lite version.
    I miss all of the features but it works
    03-03-2020 07:53 PM
  19. mustang7757's Avatar
    Probably bug in regular messenger
    03-04-2020 07:54 PM
  1. Replies: 3
    Last Post: 02-24-2020, 12:53 PM
  2. Is a Smartwatch the right choice for me?
    Last Post: 02-24-2020, 02:12 AM
  3. What is this website.
    Last Post: 02-23-2020, 11:51 PM
  4. Is my phone hacked if this is on it
    Last Post: 02-23-2020, 11:49 PM
  5. Why is Gallery not a default in android Moto C ?
    Last Post: 02-23-2020, 11:47 PM
