1. donebrasko's Avatar
    I know I am probably years behind but after I reset my network settings. I can't use my data when I'm on the phone. I'm sure it's a simple setting somewhere.
    03-30-2020 03:33 PM
  2. mustang7757's Avatar
    Which carrier? Go into settings>connection>network make sure everything on there , and your APN is highlighted on
    03-30-2020 03:47 PM
  3. donebrasko's Avatar
    Verizon... Unlocked Note 10
    03-30-2020 03:55 PM
  4. donebrasko's Avatar
    It send like something is missingCall and data at the same time-screenshot_20200330-165529_call-20settings.jpeg
    03-30-2020 03:56 PM
  5. mustang7757's Avatar
    Looks ok, did this happen right after you did network reset?
    03-30-2020 04:04 PM
  6. donebrasko's Avatar
    That's when I noticed it
    03-30-2020 04:13 PM
  7. mustang7757's Avatar
    Have you reboot the phone?
    03-30-2020 04:22 PM
  8. donebrasko's Avatar
    Where is the part in settings that gives you the option to have hd calling and voice over lte?
    03-30-2020 04:24 PM
  9. mustang7757's Avatar
    Where I mentioned in connection you were before , or dialer app settings
    03-30-2020 04:57 PM
  10. Matthew Stegman's Avatar
    on my ATT branded note 10 plus HD voice and volte is on by default. there is no software switch.
    03-30-2020 10:57 PM
  11. drewood31601's Avatar
    thanks for this post. I didnt know that feature was available on my Sprint Note 10 plus.
    mustang7757 likes this.
    03-31-2020 08:51 AM
  1. Replies: 20
    Last Post: 04-14-2020, 11:58 AM
  2. No audio in phone calls over bluetooth headsets
    By happyuser01 in forum OnePlus 3 & 3T
    Last Post: 03-30-2020, 05:26 PM
  3. Looking for a Pixel 4 user to test if my app can access the IR camera.
    By Jeremy Burk in forum Google Pixel 4 & Pixel 4 XL
    Last Post: 03-30-2020, 04:22 PM
  4. Replies: 1
    Last Post: 03-30-2020, 02:15 PM
  5. Galaxy S9+ low volume problem during call.
    By Crow819 in forum Samsung Galaxy S9 & S9+
    Last Post: 03-30-2020, 10:30 AM
