1. Samsmome's Avatar
    When I have nav Star enabled, my edge panel doesn't work. When it's not enabled, edge panel works just fine. Hmm 🤔
    Anyone else have problems???
    04-04-2020 07:39 PM
  2. sweetypie31's Avatar
    Nope. How is it not working?
    04-04-2020 07:54 PM
  3. FACTagent's Avatar
    Same problem for me
    04-04-2020 08:00 PM
  4. Borarjti's Avatar
    Navstar is working now? I just tried it and it still doesn't work since the One UI 2.0 update.
    04-04-2020 08:49 PM
  5. sweetypie31's Avatar
    Yes it's working. Did you do a restart? Cache wipe ? Those are my only suggestions to help.
    04-04-2020 09:30 PM
  6. creekwater1482's Avatar
    I'm on ATT and mine doesn't work yet. Maybe with the new 2.1 it works but I don't have that yet.
    04-04-2020 10:22 PM
  7. sweetypie31's Avatar
    That's what it is. I didn't realize he or she said they were on 2.0. it won't work until the 2.1 update.
    Laura Knotek and mustang7757 like this.
    04-04-2020 10:52 PM
  8. mustang7757's Avatar
    Works on 2.1 for me also but I use gestures not buttons so no use for me .
    MatroxD and sweetypie31 like this.
    04-04-2020 11:48 PM
  9. Samsmome's Avatar
    The side bar I can see it. It will let me side pull it but then it's gone. It's basically just a flash.
    04-05-2020 08:28 AM
  10. Samsmome's Avatar
    I did a restart. Not a cache wipe. I'll try that.
    04-05-2020 08:29 AM
  11. Samsmome's Avatar
    I got the update to 2.1 yesterday morning.
    I like to use the cat icons on the navigation bar. So when I enable it and switch to it edge panel won't pull out.
    04-05-2020 08:31 AM
  12. Samsmome's Avatar
    Just tried it again this morning. Edge panel is now working.
    Thanks all ❤️
    04-05-2020 08:36 AM
  13. j_hansen's Avatar
    NavStar is working again after 2.1 for me, I'm using gestures though, gotten so used to it.
    I'm on Nice Lock not Good Lock but they are the same really
    04-07-2020 12:32 PM
  14. sweetypie31's Avatar
    Ok now I see what the OP was talking about. When I first updated Navastar I didn't have the issue , but all of a sudden now I am. I really don't want to turn off Navastar. Ugh.
    04-12-2020 09:13 AM
  15. FACTagent's Avatar
    For me, the issue does not show up until I turn on the show / hide navigation bar function in NavStar and then Edge screen stops working. If you want to turn NavStar on just to rearrange or change the appearance of the navigation buttons that might work, but the main reason I wanted NavStar was for the show / hide navigation bar functionality. I usually use the Samsung swipe from bottom gestures but since Task Changer broke the Google assistant gesture, I was thinking about going back to the navigation bar if there was a way to hide it. Hopefully NavStar and Task Changer both get fixed soon.
    sweetypie31 likes this.
    04-12-2020 10:11 AM
  16. sweetypie31's Avatar
    I just turned off the show/hide button and now it's working again. While I'm ok with leaving my navigation bar up all the time, I hope they fix it for those of you who use the show/hide function.
    04-12-2020 10:16 AM
  1. One UI2.1 broke Google maps and Waze
    By SGN9_2019 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 04-05-2020, 11:13 AM
  2. Samsung Galaxy J6 - what is the ribbon connector to the back panel?
    Last Post: 04-03-2020, 07:30 PM
  3. Quick panel?
    By DanielLoreti in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 04-02-2020, 09:24 AM
  4. S20+: Edge lighting working but cant dismiss msgs or swipe it down!
    By shadad07 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 04-02-2020, 12:58 AM
  5. Replies: 2
    Last Post: 04-01-2020, 10:31 PM
