04-15-2020 10:46 PM
42 12
tools
  1. Matthew Stegman's Avatar
    My wife has an s10+ and I have note 10+. When we play call of duty mobile her s10+ ALWAYS loads at least 5-10 seconds faster. Its not just call of duty that loads faster, its everything she does.
    04-07-2020 08:16 PM
  2. mustang7757's Avatar
    Swap phones with her when she's sleeping
    04-07-2020 08:17 PM
  3. mustang7757's Avatar
    Note 10 has little better specs
    Laura Knotek likes this.
    04-07-2020 08:21 PM
  4. Laura Knotek's Avatar
    That might not be a good idea during the COVID-19 quarantine.
    mustang7757 and msm0511 like this.
    04-07-2020 08:24 PM
  5. mustang7757's Avatar
    true
    04-07-2020 08:24 PM
  6. Matthew Stegman's Avatar
    so question is why is it so much slower?
    04-07-2020 08:38 PM
  7. Matthew Stegman's Avatar
    I've noticed it struggles to load everything data related.
    04-07-2020 08:38 PM
  8. mustang7757's Avatar
    Mobile data only ? Both on same carrier?
    04-07-2020 08:42 PM
  9. Matthew Stegman's Avatar
    I've noticed mobile data only so far. both are on AT&T unlimited data. I've noticed this with the note 10+ I had before I got this replacement device as well.
    04-07-2020 08:48 PM
  10. mustang7757's Avatar
    Hmm...you can try in settings>general management>reset >reset network
    See if that helps
    04-07-2020 08:58 PM
  11. Matthew Stegman's Avatar
    AT&T can't (won't) explain why my note 10+ is slower than my wifes s10+. And they won't replace it for that reason.
    04-07-2020 10:12 PM
  12. Matthew Stegman's Avatar
    when I dial *#*#4636#*#* in dialer I can change network mode. For AT&T what should that be set on?
    04-07-2020 10:26 PM
  13. B. Diddy's Avatar
    Do you have a case on your phone? Some poorly designed cases can interfere with the data signal (e.g., if there's metal in the case).
    04-07-2020 10:29 PM
  14. mustang7757's Avatar
    What's the options?
    04-07-2020 10:31 PM
  15. mustang7757's Avatar
    Att won't do that ..
    04-07-2020 10:31 PM
  16. Matthew Stegman's Avatar
    so my wifes S10+ is set on LTE/TD-SCDMA/UTMS and my note 10+ is set on TD-SCDMA/CDMA/UTMS
    04-07-2020 10:34 PM
  17. Matthew Stegman's Avatar
    there are to many options to list here. take to long to type.
    04-07-2020 10:35 PM
  18. mustang7757's Avatar
    Use same profile as your wife's and test
    04-07-2020 10:36 PM
  19. Matthew Stegman's Avatar
    at first I noticed an improvement but then seemed like it got worse again.
    -WCDMA preferred
    -GSM only
    -WCDMA only
    -GSM auto (PRL)
    -CDMA auto (PRL)
    -CDMA only
    -EvDo only
    -Global auto (PRL)
    -LTE/CDMA auto (PRL)
    -LTE/UMTS auto (PRL)
    -LTE/CDMA/UMTS auto (PRL)
    -LTE only
    -LTE/WCDMA
    -TD-SCDMA only
    -TD-SCDMA/WCDMA
    -LTE/TD-SCDMA
    -TD-SCDMA/GSM
    -TD-SCDMA/UMTS
    -LTE/TD-SCDMA/WCDMA
    -LTE/TD-SCDMA/UMTS
    -TD-SCDMA/CDMA/UMTS
    -Global/TD-SCDMA
    -Unknown
    04-07-2020 11:10 PM
  20. mustang7757's Avatar
    It probably went back to default
    04-07-2020 11:11 PM
  21. Matthew Stegman's Avatar
    I'll monitor it the next few days. after I changed it it stayed the same.
    04-07-2020 11:24 PM
  22. mustang7757's Avatar
    Ok , is it set like your wife's phone ?
    04-07-2020 11:25 PM
  23. Matthew Stegman's Avatar
    LTE/TD-SCDMA/UMTS is my wifes s10+ and i changed my note 10+ to that.
    04-07-2020 11:31 PM
  24. mustang7757's Avatar
    OK good see how that goes .
    04-07-2020 11:33 PM
  25. adegbenroagoro's Avatar
    Do you have exactly the same apps as your wife?(most women have less) Could she have hers set to HIGH PERFORMANCE MODE? There are several variables.
    04-08-2020 01:49 AM
42 12
  1. Replies: 8
    Last Post: 04-12-2020, 04:28 AM
  2. Why can't I seem to get into social media accounts on my S10+
    By Android Central Question in forum Samsung Galaxy S10 & S10+
    Last Post: 04-07-2020, 08:05 PM
  3. How to root my J-7 crown
    Last Post: 04-07-2020, 03:37 PM
  4. Replies: 1
    Last Post: 04-07-2020, 01:25 PM
  5. I have 2 app widgets on my home screen and I cant click on them
    Last Post: 04-07-2020, 12:46 PM
