1. jeetu4444's Avatar
    Saw a video on youtube where with Samsung one ui 2.1 u get set 120mhz to Note 10 plus display..
    Some users reported a difference while some dint...
    Here is the video link let discuss does it really work...
    04-23-2020 10:33 AM
  2. Mike Dee's Avatar
    The hardware doesn't support it
    blackhawkhot likes this.
    04-23-2020 10:41 AM
  3. j_hansen's Avatar
    I think that was possible before 2.1 and even if you change the settings it doesn't make any difference
    04-23-2020 10:46 AM
  4. blackhawkhot's Avatar
    The OLED hardware drivers would need to support that refresh rate.
    The XDA folks says no go. Thanks Samsung...
    04-23-2020 10:47 AM
  5. mustang7757's Avatar
    Well I did this trick , now in my mind I have 120hz refresh rate
    mgbosshogg, Nostromo79 and msm0511 like this.
    04-23-2020 11:50 AM
  6. j_hansen's Avatar
    Well I tried it as well but I can't say I notice any difference
    04-23-2020 11:52 AM
  7. mustang7757's Avatar
    The biggest difference i felt , going from optimize power mode to high performance mode just very snappy
    04-23-2020 11:53 AM
  8. blackhawkhot's Avatar
    It was a mistake... thanks Samsung
    https://piunikaweb.com/2020/04/07/sa...t-too-excited/
    mustang7757 likes this.
    04-23-2020 11:57 AM
  9. mustang7757's Avatar
    Does feel more snappier though
    04-23-2020 12:01 PM
  10. blackhawkhot's Avatar
    Lol, I had a gf like that...
    04-23-2020 12:17 PM
  11. Mike Dee's Avatar
    So does a rubber band if you snap it right
    04-23-2020 05:10 PM
  12. mustang7757's Avatar
    right
    04-23-2020 05:14 PM
  13. Bkdodger1's Avatar
    It's worked for me ...I have two Note phones running 60hz next to each other for the 120hz refresh...but I seem to be scrolling slower with both at the same time or maybe I need to practice with my left ?
    MoreDef likes this.
    04-23-2020 05:24 PM
  14. Mike Dee's Avatar
    The hardware doesn't support so it's not 120hz
    04-23-2020 05:27 PM
  15. Bkdodger1's Avatar
    I disagree ! Both my phones are running 60hz which equals 120hz ...
    MoreDef likes this.
    04-23-2020 05:29 PM
  16. Mike Dee's Avatar
    Only if you connect them in series
    04-23-2020 05:30 PM
  17. j_hansen's Avatar
    You have to do it the right way around though or you will end up with 0 hz :-)
    MoreDef and Bkdodger1 like this.
    04-24-2020 01:51 AM
  18. me just saying's Avatar
    just like overclocking a pc, do it at your own risk
    04-24-2020 02:08 AM
  19. MoreDef's Avatar
    I'm just waiting for the next update, which enables the IR blaster.
    04-24-2020 03:48 AM
  20. j_hansen's Avatar
    Yeah, that'll be deadly LOL
    04-24-2020 04:09 AM
  21. jeetu4444's Avatar
    Hows the battery life in performance mode ?
    04-24-2020 07:49 AM
  22. Mike Dee's Avatar
    And you will blow the reverse polarity diode
    04-24-2020 09:04 AM
  23. mustang7757's Avatar
    Very good , a day and 9.5hrs to 11 hrs SOT
    04-24-2020 09:25 AM
  24. blackhawkhot's Avatar
    It lased and there's a hole in my center vision now.
    Cool, android laser!
    04-24-2020 09:26 AM
  1. Pinch to zoom constraints
    By pauly814 in forum Samsung Galaxy S20 & S20+ & S20 Ultra
    Last Post: 04-23-2020, 10:01 PM
  2. any way to know if i received refurbished device?
    Last Post: 04-23-2020, 06:45 PM
  3. Why is Home Screen on s10e getting overlaid?
    Last Post: 04-23-2020, 12:14 PM
  4. Can't make a contact a favorite
    Last Post: 04-23-2020, 11:23 AM
  5. Replies: 0
    Last Post: 04-23-2020, 08:08 AM
