Best Clear Cases for Galaxy Note 10 Plus (that doesnt yellow)
PuertoRicanSloth
4
I'm looking for a clear case that wont yellow , or maybe very minimal as I have decided to pick up the Aura Glow color way , I saw a thread for the note 9 saying that the VRS Design was great an minimal to no yellow , wanted to know if its true?
msm0511
Trusted Member
Aug 23, 2014
4,619
9
38
Not sure about that one, but both Speck and Tech21 sell clear cases with a guarantee they'll replace them if they yellow
Serkle K
1,459
35
48
I have the Caseology Skyfall clear case on my Note8. They advertise it, that it wont turn yellow. Two years later. It's yellow.
I picked up the same case for my Note10+ so I have it as son as it arrives.
Misterb
742
Those clear cases love to display the dog hair, dirt, dust, and grime that fills up between the case and the back of your phone. No thanks
fredwardnelson
244
From my experience most cases do eventually turn yellow, I read an article about it once that went into the science of it, its inevitable, but buying one every two years sounds great.
CKwik240
738
18
It really depends on the materials. TPU tends to yellow. Polycarbonate does not. My N9 and S9+ had essentially the same case (different branding but looked identical). It has a matte colored edge with polycarbonate back. Haven't found one looks it for the N10 series though. Amazon just delivered one with a tempered glass back, but the sides are probably a clear TPU. I'll have a better look at it when I get home.
GrumpyMomofMacR
141
11
18
I like Ringke Fusion Clear on my S10+. The edges are turning slightly yellow about 4 months on. The back panel remains perfectly clear. I see they’re also selling a version of the clear that has smoke grey edges. That won’t turn yellow. I intend to pick one up for my Aura Glow Note 10 Plus.
Katrina White1
2,838
1,010
113
I 2nd that emotion! I just bought one. I ordered the black phone, so the smoked sides should work well. I've been using a clear Ringke since the 5.
CKwik240
738
18
I searched for the one I have on my N9 and looks like it showed up over the weekend on Amazon. It's made by Tozo. But it's only available in Black and clear. The clear one looks like it still uses clear TPU and may still yellow over time. Hopefully they come out with a blue one at some point.
LuckiestLiz
307
45
28
My Note 9 has been in a clear Tech21 case for the past year, it looks good on the phone but when off has a bit of a dingy look - surprisingly though, not yellow like I usually see. It has protected my phone from numerous drops (nothing crazy) so I'm thinking about giving it another go with my Note 10. (Although, as time passes I am regretting Aura Glow and maybe I'll seek a solid case to hide it! :-\)
Bkdodger1
3,646
2,255
113
I just received the Ringke Air clear... It will be for pick up day... One on my S10+ is Fusion which is more rigid..
Serkle K
1,459
35
48
It will still turn yellow, unfortunately. I had one a few years back, in the smokey grey color, for my BlackBerry Passport. I specifically got the grey because I too thought it wouldn't change, but it did.
mak916
634
117
43
I have a Spigen clear kickstand case on my Note 8. It has not yellowed. It will be a year this month since I've had it. I've had it on ever since I got it.
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
The best cases that won't yellow are hard backed clear plastic or tempered glass backed cases. I will be doing a review of the tempered.glass.ones made by ESR anyone interested I will be posting a 30 percent off code for their cases and screen protectors.
JeromeM
123
I ordered the Spigen Ultra Hybrid S in the "Matte Black" which means the back is clear but the sides and kickstand are Matte Black. Hoping it will look good with the Aura Glow but not get as grungy as an all clear case!
