Best Clear Cases for Galaxy Note 10 Plus (that doesnt yellow)
RobSteal
77
I like Ringke Fusion Clear on my S10+. The edges are turning slightly yellow about 4 months on. The back panel remains perfectly clear. I see they’re also selling a version of the clear that has smoke grey edges. That won’t turn yellow. I intend to pick one up for my Aura Glow Note 10 Plus.
Does Samsung Pay work with your phone with the Ringke Fusion Case?
I only use Ringke cases (b/c of the loop on the side), but I've ALWAYS had problems using Samsung Pay with Ringke Fusion cases. I think it's b/c of the HARD plastic back (which only the Fusion has).
I have ZERO problems with their Onyx and Air lines. Only Fusion gives me problems. And that's with the Note 9, Note 8, and Note 7 (first phone I started to use Ringke cases).
RobSteal
77
I just received the Ringke Air clear... It will be for pick up day... One on my S10+ is Fusion which is more rigid..
Have you tried using Samsung Pay with your Fusion case? I've ALWAYS had problems with Ringke's Fusion, but ZERO problems with their Onyx and Air lines.
Mike Dee
Ambassador
May 14, 2014
23,368
192
63
I don't doubt you but it seems strange that the fusion would cause an issue
sweetypie31
4,484
185
63
I have the ringke fusion clear for my n9 and Ive had no issues using Samsung pay with it on.
dario12v
251
4
18
My Note 9 has been in a clear Tech21 case for the past year, it looks good on the phone but when off has a bit of a dingy look - surprisingly though, not yellow like I usually see. It has protected my phone from numerous drops (nothing crazy) so I'm thinking about giving it another go with my Note 10. (Although, as time passes I am regretting Aura Glow and maybe I'll seek a solid case to hide it! :-\)
Umnnn yeah that glow is a little over the top for my taste , i went with the aura blue from samsung.com
You still do have time to cancel and re-order , go and see the phones in person , then make a decision
mak916
634
117
43
Hmm see I don't usually put a screen protector on so I was hoping to avoid that, so with this case I'd probably still need one? I cracked a screen with a otterbox commuter twice than put a defender on (luckily Verizon's screen repair is only $29)
Yes, with this case you would still need a screen protector. Sprint's screen repair is the same price now. I always have one on just in case. Last time my glass screen protector broke I was out of town. So glad I had it on. I've never had a broken screen before.
RobSteal
77
I actually tested this specifically on my Note 9 AND my Note 8 (back when I had it). Samsung Pay will still work with the Fusion case, it's just that it takes SEVERAL MORE swipes/passes for the payment to register. With the Onyx or Air case, it usually swipes successfully on the first time (with occasional hiccup here and there).
It's a night and day difference. And it CAN'T be a coincidence since it happens on BOTH phones.
Anotherusr
97
Dang, thanks for the reply. Guess I'll be in search of a screen protector that will work with the in screen fps and not break the bank.
reintgenrc
101
I have had a Note 9 since launch and my Otterbox Symmetry clear yellowed after a few months. I replaced it with an ESR Mimic case which has a tempered glass back that should not yellow as it's not TPU. So far it (including the non-glass sides) looks perfect with zero signs of yellowing.
DragnDon
