Javier P
Ambassador
I like Ringke Fusion Clear on my S10+. The edges are turning slightly yellow about 4 months on. The back panel remains perfectly clear. I see they’re also selling a version of the clear that has smoke grey edges. That won’t turn yellow. I intend to pick one up for my Aura Glow Note 10 Plus.
I just received the Ringke Air clear... It will be for pick up day... One on my S10+ is Fusion which is more rigid..
I don't use Samsung Pay... I have the Fusion on my S10+ maybe give it a set up try it out..Have you tried using Samsung Pay with your Fusion case? I've ALWAYS had problems with Ringke's Fusion, but ZERO problems with their Onyx and Air lines.
I don't doubt you but it seems strange that the fusion would cause an issueDoes Samsung Pay work with your phone with the Ringke Fusion Case?
I only use Ringke cases (b/c of the loop on the side), but I've ALWAYS had problems using Samsung Pay with Ringke Fusion cases. I think it's b/c of the HARD plastic back (which only the Fusion has).
I have ZERO problems with their Onyx and Air lines. Only Fusion gives me problems. And that's with the Note 9, Note 8, and Note 7 (first phone I started to use Ringke cases).
I have the ringke fusion clear for my n9 and Ive had no issues using Samsung pay with it on.Does Samsung Pay work with your phone with the Ringke Fusion Case?
ordered the ESR. thanks for the promo code mike
Ditto!ESR Mimic Series 9H Tempered-Glass Back Cover, Clear
https://www.amazon.com/dp/B07V6H97MR?tag=hawk-future-20&ascsubtag=UUacUvbUpU6603067
Code: AXQH4TTJ
My Note 9 has been in a clear Tech21 case for the past year, it looks good on the phone but when off has a bit of a dingy look - surprisingly though, not yellow like I usually see. It has protected my phone from numerous drops (nothing crazy) so I'm thinking about giving it another go with my Note 10. (Although, as time passes I am regretting Aura Glow and maybe I'll seek a solid case to hide it! :-\)
I got this ESR clear case with metal kickstand. The link is to the company's page but I bought it on Amazon. https://www.esrgear.com/products/galaxy-note-10-plus-metal-kickstand-case/
Hmm see I don't usually put a screen protector on so I was hoping to avoid that, so with this case I'd probably still need one? I cracked a screen with a otterbox commuter twice than put a defender on (luckily Verizon's screen repair is only $29)
Yes, with this case you would still need a screen protector. Sprint's screen repair is the same price now. I always have one on just in case. Last time my glass screen protector broke I was out of town. So glad I had it on. I've never had a broken screen before.
