1. bmandrews7's Avatar
    Would like to start a thread with list of white dome compatible cases. Please reply with tested case and results. Pictures if possible. Still waiting on my preorder will reply with my findings when I can.
    08-18-2019 01:09 PM
  2. haticK's Avatar
    Every Spigen case should work with it. They leave a lot of room on the sides while still adding a lip so it can be placed face down.
    08-18-2019 01:57 PM
  3. jlangner's Avatar
    On Note 9 and S10+ I used whitestone with Spigen Rugged Armor with no issues.
    08-18-2019 07:40 PM
  4. Serkle K's Avatar
    I test fitted my Whitestone Dome with my Caseology Skyfall case, and it has plenty of room. Just waiting on the device to test fit all 3 of them together before I put the adhesive on with the case.
    08-20-2019 04:32 PM
  5. Casper4's Avatar
    Good idea on the test fit, I tried it with the cases I have. It looks to have plenty of room on the Otterbox defender and fits but tight on the Spigen Tough armor and ultra hybrid s.
    Serkle K likes this.
    08-20-2019 06:50 PM
  6. Serkle K's Avatar
    I realized I had to test fit it, when I got it for my note8 and it was said to be compatible with a couple cases I had, but it just didn't seem to work on one of them. After having the screen protector do it's job and save mu device, I ordered the replacement screen protector, and it was in that moment, I knew to test fit it so I knew exactly where the screen needed to line up for everything to fit perfectly. I haven't had any compatibility issues since then, over the last two years!
    goojman likes this.
    08-20-2019 11:06 PM
  7. EndymionXT's Avatar
    Anyone know if the ESR Hybrid Glass case will be compatible with it?
    08-21-2019 07:06 PM
  8. bandofbrothers2112's Avatar
    I have two cases.
    Samsung Black Leather case and the Spigen Ultra Hybred clear case and both are fine with the Whitestone.
    08-31-2019 01:12 AM
  9. tsells's Avatar
    Whitestone Dome is compatible with Tech 21 Pure Clear and Spigen Slim Armour Essential.
    08-31-2019 06:38 PM
  10. scmcc16's Avatar
    Anyone confirm that the Whitedome fits the Otterbox Commuter?
    10-24-2019 08:17 AM
  1. Case for Tab A?
    By bigpapa7272 in forum Samsung Galaxy Tab A 10.1 (2019)
    Last Post: 09-28-2019, 12:05 AM
  2. Best Rugged Note 10 Plus Cases For Your Money -- Otterbox UAG and ArmadilloTek
    By SuperLeakTX in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 09-24-2019, 04:33 AM
  3. Spigen Slim Essential case New clear case from spigen
    By dario12v in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 08-31-2019, 01:44 PM
  4. Moment Case and Lens ?
    By RC51 RIDER in forum Google Pixel 3a & Pixel 3a XL
    Last Post: 08-17-2019, 12:26 PM
  5. Need a rugged case
    By JustBlaze330 in forum Pixel 2 Accessories
    Last Post: 08-15-2019, 09:17 PM
