1. notefreak's Avatar
    Is there an issue if I use a longer cable from my Note8 15w charger with the new 25w charger? Any downsides? Thanks all!
    08-20-2019 01:52 PM
  2. SpookDroid's Avatar
    Depends on the cable. For 25W quality cables and first party ones should work, but for 45W you might run into issues.
    https://www.androidcentral.com/edito...eg-and-note-10
    08-20-2019 02:15 PM
  3. Serkle K's Avatar
    The only issue might be that the new 25w charging brick is a Type-C port. That's why they include the USB-C to USB-C cable. Is your 15w charger a Type-C port?
    08-21-2019 09:40 AM
  4. notefreak's Avatar
    Yeah, it is not, I figured that out earlier and felt really silly LOL .
    Serkle K likes this.
    08-21-2019 10:48 AM
  5. DrRafaelPenguin's Avatar
    Hi, guys. New user here but I had a question regarding this topic. Would this cord from Anker be good to use since it's USB C to C? And also, does this mean we aren't able to use any of the other chargers with previous phones, or will it just charge slower if we do? Thanks for the help!
    https://www.amazon.com/dp/B01LNA0XCU...cUvbUpU6613059
    08-21-2019 11:33 AM
  6. yhboy's Avatar
    The Apple USB-C to USB-C cable is currently on sale on Amazon for $13.99. It is a solid cable and supports up to 87W guaranteed.
    08-23-2019 12:52 AM
  7. chanchan05's Avatar
    Well, there's a Type-A to Type-C adapter in the box, but it won't charge as fast. Type-A cannot carry as much current as Type-C, so there would probably be no difference if you just used the S8 charger instead.
    08-23-2019 01:28 AM
  8. amyf27's Avatar
    I have quite a collection of USB C cords some from Samsung devices and others from third-party typically stores like Walgreens Etc. They all work, though I'm thinking they may charge a little slower then the stock cord and wall charge setup that came with the Note 10 plus
    08-23-2019 05:12 AM
  1. Why my phone is saying app not allowed by device owner
    Last Post: 08-27-2019, 09:53 AM
  2. What 3D objects will you scan with the depth camera?
    By gyounk in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-21-2019, 08:14 PM
  3. My phone is vibrating when I play Pandora.
    Last Post: 08-21-2019, 11:09 AM
  4. How do you delete the Android Pie update file from a Samsung S9+?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 08-21-2019, 07:31 AM
  5. Anybody have a link to the Note 10+ Reddit wallpapers yet?
    By Chitown28 in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 08-20-2019, 05:52 PM
