1. Serkle K's Avatar
    Need some insight, please.
    I'm getting the Note10+ and (probably like most people) I currently have a few 3rd party chargers and battery packs.
    With the large amount of info, much of which doesn't really make much sense to me, I'm trying to figure out if the ones I use the most often are compatible with the new Notes.
    I currently use (link below) this on my night stand with an old BlackBerry Passport as my alarm clock in a desktop stand, and the Fast Wireless charger that came out with the S8/Note8 devices. I keep my Note8 set to normal charging speeds on wireless, and fast charge when plugged in.
    Anker Quick Charge 3.0 63W 5-Port USB Wall Charger, PowerPort Speed 5 for Galaxy S10/S9/S8/S7/S6/Edge/+, Note 8/7 and PowerIQ for iPhone XS/Max/XR/X/8/7/6s/Plus, iPad, LG, Nexus, HTC and More https://www.amazon.com/dp/B01IUTIUEA...cUvbUpU6612490
    And for travel, I have this...
    Anker PowerCore+ 26800, Premium Portable Charger, High Capacity 26800mAh External Battery with Qualcomm Quick Charge 3.0 (in- and Output), Includes PowerPort+ 1 Wall Charger https://www.amazon.com/dp/B01K6TA748...cUvbUpU6612490
    And for my car, I have this...
    Roav SmartCharge Spectrum, by Anker, 30W Dual USB Car Charger with Quick Charge 3.0, for iPhone X/8/7/6s/Plus, iPad Pro/Air 2/Mini, Galaxy S8+/S8/S7/S6/Edge/Plus, Note 8/5/4, LG, Nexus, HTC, and More https://www.amazon.com/dp/B075RV7KRM...cUvbUpU6612490
    I just want to make sure they're compatible and won't cause any issues for any devices on either end.
    Also, if you have any recommendations for USB-C to USB-A cables that will work on these devices, I would appreciate them as well.
    Thank you!
    08-21-2019 05:55 AM
  2. chanchan05's Avatar
    I don't see any reason why they won't be compatible as long as the plug inserting to the Note is USB C
    08-21-2019 07:01 AM
  1. Old, old (but surprising!) tablet, Note 10.1 - charging
    By RosLamb in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 09-03-2019, 09:30 AM
  2. My s9 wont charge using a cable but will charge using wireless charger
    Last Post: 08-21-2019, 03:47 PM
  3. Replace Samsung Galaxy Tab 4 power charging port?
    Last Post: 08-21-2019, 03:34 PM
  4. Why is my phone charging the USB connector?
    Last Post: 08-21-2019, 02:19 PM
  5. Touch Screen malfunctioning but working, red light blinking when charging ZTE
    Last Post: 08-21-2019, 10:53 AM
