01-19-2020 08:52 PM
41 12
tools
  1. NIZMOZ44's Avatar
    Sorry you had issues. Mine is about 3 years old now and still going!
    That was a great charger.... Except when it breaks. It snaps shut so hard, it puts a shock load on the tab that eventually causes a figure failure. They really needed to put a damper to allow the closer action down without reducing clamping force. It was replaced under warranty, but I have it away and went with the new magnetic version.
    I agree the proclip hardware can be great, but that's not the case for all cars.
    08-26-2019 05:55 PM
  2. amyf27's Avatar
    I got this new one today and like it. It holds my 10+ even with the Otterbox Defender case on. I have it on a dash mount setup currently.
    Bkdodger1 likes this.
    08-28-2019 07:48 PM
  3. CKwik240's Avatar
    To be fair, I drive a lot. I work 6 miles from home and I still manage to put on about 30k miles a year. And most of that is local so my mount saw a lot of opening and shutting events. But if I broke it in less than a year, then I would expect it would break again in a similar amount of time. Thus, I moved on.
    amyf27 likes this.
    08-28-2019 09:19 PM
  4. anon(7901790)'s Avatar
    I'm keeping my iOttie mount. It worked great with my Note 8 and it's working great with my Note 10+.
    toenail_flicker likes this.
    08-29-2019 02:29 AM
  5. amyf27's Avatar
    Here's the actual mount. Holding very well on the dash.
    08-29-2019 10:37 AM
  6. daninbluemd's Avatar
    Several months ago I purchased and I Otti vent mount for my. It's a tad on the flimsy side and the little arms are tiny Plus a smooth case may slide when being held so I have these rubber bands rig on it to keep that from happening.
    I'm going to look into getting something sturdier to use possibly a dash mount. I do have a windshield mount that's very sturdy I might use that for a little while. I like the position of where the air vent is though it's very easy to reach and it's not in the way of my viewing.
    I have one of those "as seen on TV" vent mounts from years ago (prob. 5-6 years old, no idea if still made) and it still works great.
    Looks like it's still made (https://www.asseenontvwebstore.com/C...lever-grip.htm)
    11-19-2019 02:27 AM
  7. amyf27's Avatar
    Since I had posted that originally, I've gotten a great dash mount for the Note, also one for the Tab S6.
    11-19-2019 09:23 AM
  8. _YoKolorMeBadd's Avatar
    Does the wireless one actually charge? I bought one a few years ago and it would never constantly charge my phone. I think I had a XS Max at the time..
    12-06-2019 10:09 AM
  9. CKwik240's Avatar
    No reason it shouldn't. I am currently using a different one from iOttie. My gf uses it to charge her iPhone 11 plus all the time in her car and mine.
    _YoKolorMeBadd likes this.
    12-06-2019 11:13 AM
  10. mhynek's Avatar
    I use a barely there case with imbedded metal plates with a Qi magnetic mount. It works well and very convenient.
    PITAKA MagEZ Case Compatible with Samsung Galaxy Note 10+ 6.8" Aramid Fiber Ultra Slim Fit for Samsung Note10 Plus Super Durable Phone Case with Soft 3D Grip Touch Back Cover- Black/Grey(Twill) https://www.amazon.com/dp/B07XDYLV2T...cUvbUpU6702891
    SCOSCHE MQ2WD MagicMount Charge Universal 10W Magnetic Qi-Certified Phone/GPS Suction & Adhesive Wireless Charge and Mount with Car Charger for The Car https://www.amazon.com/dp/B07F1TQ86H...cUvbUpU6702891
    12-08-2019 07:34 AM
  11. Hermes Hidayat's Avatar
    Here's the actual mount. Holding very well on the dash.[IMG=485x1024]https://uploads.tapatalk-cdn.com/20190829/1d16eb1d4df01e8ba8eb2e41b70dffd3.jpg[/url][IMG=485x1024]https://uploads.tapatalk-cdn.com/20190829/6bbc54a34e6da1ce177c88f864d4179c.jpg[/url]
    Im guessing holding well wouldnt work on Indonesian roads... Potholes and bumps here are crazy...
    12-08-2019 03:32 PM
  12. DARK Vader777's Avatar
    iTLTL universal car air vent has been my go to cell phone in car holder.
    You can get it at Amazon for 10.99.
    The best part is it remains stable no matter what. But most of all in New Jersey you can't use a Windshield mounted in car phone holders without getting stopped by the police.
    It is vent mounted and it has enough coverage on the back to deflect any heat coming out of the vents. Amazon will hook you up.
    I've had a few and they always fell or wiggled loose. Soon as they would I'd get my money back from Amazon and try another.
    I grabbed 1 in May of 2019 and only remove it to clean vents.
    Amazon reviews are questionable at times, but they got this one right.
    12-31-2019 10:21 PM
  13. Super Dave426's Avatar
    Well I just got the WeatherTech Cupfhone and I can't believe how awesome it is. Phone slides in and never moves. I have 3 cup holders on the center console in my GMC Sierra and this one is just perfect.
    Just wanted to add when I remove my phone from the holder it's nice not having to look for a release button, just slide up and out.
    https://www.weathertech.com/products...rtech-cupfone/
    01-13-2020 05:39 PM
  14. Mike_Luchia's Avatar
    Just bought the https://www.amazon.ca/gp/product/B07...cUvbUpU6722223 Fiora 15W Qi Wireless Fast Charge and love it. Comes with 3 different mounts (window, CD and vent mounts) 15 Watt fast wireless charging and auto close and open. Very secure and I'm happy with it so far.
    01-13-2020 07:09 PM
  15. trucksmoveamerica#AC's Avatar
    I use a cup holder as I drive a smaller car don't like the vents covered..
    WeatherTech
    I've seen these advertised on TV. How do you like it now.
    01-19-2020 08:43 PM
  16. Bkdodger1's Avatar
    It's perfect for me ... I can adjust easily for phones depending on if I have different cases or naked phone ... Only negative you are unable to have phone in landscape view ...
    01-19-2020 08:52 PM
41 12
  1. S-View Cover on a Car dock
    By j_squared in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 08-21-2019, 04:16 PM
  2. How to display emails on dash screen in cars?
    By gps360 in forum Samsung Galaxy S10 & S10+
    Last Post: 08-17-2019, 12:12 AM
  3. Charging via USB in the car
    By eric002 in forum Android Q
    Last Post: 08-16-2019, 07:29 AM
  4. Qi Wireless Car Charger Mount
    By bobbyleebrown.bb in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 08-15-2019, 08:20 PM
  5. Note 8 stopped binding for MUSIC in car, only works for calls?
    By SenorApples in forum General Help and How To
    Last Post: 08-13-2019, 03:42 PM
