1. uncreativeartist's Avatar
    So awhile back someone I worked with had this metal phone case on his phone. It was screwed together and pretty thin yet felt very sturdy. I was wondering is there a case like that for the Note 10+. I have been looking for cases but none interest me, they are either these super thick overpriced cases or cases that are bedazzled or have rain fall sparkles in them.
    Ultimately I would just like to carry the phone as is but clumsiness and my luck, that will never work. I know I'm a bit picky for things like this but there has to be a case I actually like. I know with a possible metal case I can get it anodized or cerakoted or something to get a colour I like but the current choices I have found are terrible.
    09-07-2019 09:01 PM
  2. KruseLudsMobile's Avatar
    Check out Pitaka
    09-07-2019 10:04 PM
  3. B. Diddy's Avatar
    You have to be careful with metal cases -- they need to be designed so that the metal doesn't block the phone's reception. Be wary of cheap metal cases from China, since the manufacturers probably didn't consider that.
    09-08-2019 12:11 AM
  4. bandofbrothers2112's Avatar
    I agree.
    The good designs have plastic inserts in them etc where the antennas are.
    Even then some signal loss could occur I'd imagine.
    B. Diddy and uncreativeartist like this.
    09-08-2019 12:47 AM
  5. B. Diddy's Avatar
    Ah, the price of bling.
    09-08-2019 01:02 AM
  6. uncreativeartist's Avatar
    B.Diddy, I'm not into bling, I didn't ask for diamond encrusted titanium cases. I asked for metal cases, I thought it looked pretty good and seemed like an obvious choice for protecting a phone. Eff bling and those that live for it, I rather have food in my belly and a roof over my head than the most outrageous overpriced crap.
    I never thought about a case blocking the phone's signal. Not that I'm getting the best signal/reception anyway. Thanks for that bit of info all. I am now looking at other cases.
    09-08-2019 06:03 AM
  7. JOEY NEAT's Avatar
    Gorilla Cases
    uncreativeartist likes this.
    09-08-2019 10:36 AM
  8. B. Diddy's Avatar
    LOL, I agree about bling. I didn't mean that you were looking for a blingy case -- just that the whole metal interference thing also causes problems for those blingy cases (you had mentioned bedazzled cases, not that you were ever interested in getting one).
    09-08-2019 11:27 AM
  9. uncreativeartist's Avatar
    Ok, sorry then. lol
    B. Diddy likes this.
    09-08-2019 11:32 AM
  10. icnmayhem's Avatar
    also screws with wireless charging.
    09-12-2019 07:47 AM
  11. SuperLeakTX's Avatar
    Nah, mine has metal frame, but it works perfectly
    https://www.amazon.com/gp/product/B0...cUvbUpU6716729
    01-03-2020 01:11 AM
  12. B. Diddy's Avatar
    Metal wouldn't interfere with wireless charging if it's around the edge of the phone, like with that case. But if there's metal covering the back of the phone, that would interfere.
    01-03-2020 01:45 AM
  1. Minimalist cases with kickstand for 10+
    By srgonu in forum Samsung Galaxy Note 10 & Note 10+ Cases & Accessories
    Last Post: 01-04-2020, 10:02 AM
  2. Replies: 1
    Last Post: 09-07-2019, 08:05 PM
  3. Note9 - how to download jpeg files to phone?
    Last Post: 09-07-2019, 04:49 PM
  4. Replies: 4
    Last Post: 09-07-2019, 11:36 AM
  5. Why wont my phone read my sims card
    Last Post: 09-07-2019, 01:05 AM
