1. mozman's Avatar
    My car doesn't have audio Bluetooth so I need to use the 3.5mm audio adapter to listen to music in my car from the phone. For the note 10i found this 2 in 1 adapter that lets me listen to music and charge my N10+. I scoured Amazon and read the Q&A and reviews and found this to have confirmed to work with the N10. So far I'm happy with it.
    For those looking for something like this I hope this helps.
    There's a truck to get it to work. I have to follow these step of to get music to play:
    1) I have to plug the audio cable into the adapter
    2) plug the adapter into the N10 in the USB C Port.
    3) play your music to confirm it works
    4) plug your charger cable into the adapter
    Now your phone will charge and play music in the car.
    09-07-2019 09:28 PM
  2. KruseLudsMobile's Avatar
    My car doesn't have audio Bluetooth so I need to use the 3.5mm audio adapter to listen to music in my car from the phone. For the note 10+ found this 2 in 1 adapter that lets me listen to music and charge my N10+. I scoured Amazon and read the Q&A and reviews and found this to have confirmed to work with the N10. So far I'm happy with it.
    Now your phone will charge and play music in the car.https://uploads.tapatalk-cdn.com/201...5e194432c1.jpg
    I have decided against this when reading (see attached) - ? this:
    runfar262 likes this.
    09-07-2019 10:00 PM
  3. scott15851's Avatar
    I have decided against this when reading (see attached) - ? this:[IMG=1023x429]https://uploads.tapatalk-cdn.com/20190908/28bab2512c31a4e71fd907fe10d33fed.jpg[/url][IMG=405x897]https://uploads.tapatalk-cdn.com/20190908/6f7f2782f7514a24e3b33c2f80e75850.jpg[/url]
    Thank you
    09-07-2019 10:05 PM
  4. mozman's Avatar
    Thanks for sharing.
    Of the 2 concerns noted at the end the earphones.... Or in my case, my car stereo is working. I'll post about the overheating if I notice any.
    KruseLudsMobile likes this.
    09-07-2019 10:39 PM
  5. KruseLudsMobile's Avatar
    Thanks for sharing.
    With the 45 Watt you might blow out the earbuds or cause some real major league heating!
    09-07-2019 10:53 PM
  6. mozman's Avatar
    I'm using a car charger adapter that is QC2.0. I should be ok.
    09-08-2019 09:29 AM
  1. Samsung Trade-in, What Would You Do
    By toenail_flicker in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-08-2019, 01:28 PM
  2. Where are my files after filling out a PDF using Write on PDF app in my S8+?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 09-08-2019, 11:18 AM
  3. Your device is corrupt. It cant be trusted and will not boot. How do i fix this?
    Last Post: 09-07-2019, 09:52 PM
  4. How I got 360.00 in credits from Samsung promotions.
    By illpoetic in forum Samsung Galaxy Note 10 & Note 10+ (2019)
    Last Post: 09-07-2019, 06:51 PM
  5. Where are my files after filling out a PDF using Write on PDF app in my S8+?
    Last Post: 09-07-2019, 05:42 PM
