[AT&T] Best Custom ROM
destefmx6
126
Ok, I did use the search feature first, but nothing specific enough came up. So, here goes, "Which is the best Custom ROM for AT&T sgh-i317? and why?" please? thx. :)
- I would like to utilize the features the phone is "actually" capable of using. After the update 4.1.2, I didn't like the fact that I can't add any app to the multi-window pane.
-I would like to have the ability to do the things that Sammy says the phone can do, while att stymies it....
- I guess I just want as much usability as the phone is capable of.
sqa4life
590
Re: Best Custom ROM
CleanROM 3.5.
You can do all that you mentioned, plus more
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
destefmx6
126
Re: Best Custom ROM
I dowloaded:
CleanRom 3.5
CleanRom SE 1.0
JediX
NOTEorious
& SAURom
I'm inclined to just install the SE, I think it's 3.5 with ATT features, but I'm not in a rush. So I figured I would ask here. Thanks Sqa4life!
sqa4life
590
Re: Best Custom ROM
I dowloaded:
CleanRom 3.5
CleanRom SE 1.0
JediX
NOTEorious
& SAURom
I tried the SE but didn't like it. It sucks memory faster than 3.5. Plus, I couldn't adjust the row/column for the home screen on the SE. So, I went back to 3.5 and stay :)
Memory never dropped below 1000MB on 3.5
DroidXcon
11,102
3,392
Re: Best Custom ROM
Do you mean it sucks battery faster? Because this is an android device not a windows device. Memory is utilized differently unused memort is inefficient
From my Galaxy Note 2 via Tapatalk
MatroxD
482
Re: Best Custom ROM
CleanROM 3.3-very good
Cleanrom 3.5-uses more memory
Cleanrom ATT-not bad
Cleanrom Ace-so far very fast but if I run into issues I will report.
I'm using the Ace at the moment.
Sent from Note 2
Jan 6, 2013
12
Re: Best Custom ROM
Like MatroxD I'm running Cleanrom Ace 4.0.5 that I grabbed last night, still working great, I've been heavy user all night/day long and I'm finally down to 15% battery after 18 hours... I'm considering that pretty good since I re-downloaded about 70 apps, setup all my home screens, settings, etc. and have been cooking facebook, internet, youtube, etc. all day long on wifi. So far no issues
destefmx6
126
Re: Best Custom ROM
Is there a way to backup the apps so we don't have to download/install them all again?
destefmx6
126
Re: Best Custom ROM
What did you use to get the 5 column pages? Or is it part of the tweaks in the ROM?
jdub1981
1,382
Re: Best Custom ROM
Im using cleanrom att se. It works just fine. I like 0 bloat.
Also for those that change roms alot you might try titanium backup. It lets you restore apps and app data after wipe and rom install. . Took me about 3 minutes to restore 77 apps last night. When you restore only restore white and yellow2 apps. Red apps are data not compatible with your new rom. You will know what im talking about when you try it.
destefmx6
126
Re: Best Custom ROM
The Titanium Backup was the first thing I did when I rooted.
sqa4life
590
Re: Best Custom ROM
So, do you delete or disable all the red stuffs?
jdub1981
1,382
Re: Best Custom ROM
Before the wipe do a full systen backuo with titanium backup. Designate your external sd card to hold the backup. Then after your wipe and rom install, first thing to do is go to playstore and download titanium backup. Click top right to restore then restore all apps with data. Next screen make sure only thw white and possible yellow apps..your designation here...are checked. This will install only this data. Dont worry about the red stuff. Its left over system data from the previos rom. If you install it expect problems with your phone. I know cuz I did it.
MatroxD
482
Re: Best Custom ROM
Not meaning to Jack the thread, but quick question guys.... Are you running 64gb sd cards? The reason I'm asking is that I'm only running a 32 and would like to upgrade, but I'm just wondering (with my skeptical nature) if this transfer is going to loose some backups.
The media and other transfer I'm not worried about. I know I can just copy the complete structure from one card to the next, but this is going to smooth for me. I have a feeling of I do that, this will be the cause of issues?
Sent from Note 2 via Tapatalk
Admorris
Active member
Nov 18, 2012
38
Re: Best Custom ROM
Jedi XP8 with Nova Launcher and Perseus new kernel cannot be beat...as fluid as you'll ever get and good battery life.
Sent from my SGH-I317 using Tapatalk 2
destefmx6
126
Re: Best Custom ROM
I am also running Sandisk's 32gb and was wondering the samething...
