1. hpye's Avatar
    my note 2 has imei number but when i enter the number in the imei checking website it say it is not available, what to do?
    What website should i check to see the manufacturer name, etc..
    i bought it from expansys usa $649
    and also my dont have the sticker on the box saying do not accept if the seal is broke label, it just came without it. Is it fake?
    02-08-2013 04:20 AM
  2. bigliquid530's Avatar
    Kinda curious why would you buy it from there
    02-15-2013 08:03 AM
  3. ReuvenNY's Avatar
    Are you using Check IMEI - IMEI.info ?
    Make sure that you do not confuse the o with 0 and the number 1 with letter l
    02-16-2013 10:15 AM
  4. Kelly Kearns's Avatar
    Why not just register it at Samsung? They will tell you when it was manufactured and then also send you a 50% discount coupon code for any accessories.
    Sent from my AWESOME Note 2
    02-16-2013 04:57 PM
  5. Raj29P's Avatar
    what web site you used to check your IMEI
    02-17-2013 05:14 PM
  6. Kdubbn's Avatar
    If you'd like I can have my partner check it through his work. Does it for my buddies all the time before they buy phones from Craigslist or third party places all the time.
    Sent from my SAMSUNG-SGH-I717 using Android Central Forums
    02-17-2013 06:13 PM
  7. Njshoregurl's Avatar
    Now I know to buy from best buy, or , or even radio shack.... cheaper at amazon with att contract BUT......
    02-17-2013 07:23 PM
  8. Los Becky's Avatar
    check the battery, back cover, usb interface, etc.. fake can be easily spot,
    03-05-2013 02:06 AM
  1. Replies: 3
    Last Post: 03-24-2013, 12:29 AM
  2. Is my Note 2 defective
    By BLACKELITE0095 in forum Samsung Galaxy Note 2
    Last Post: 01-17-2013, 06:55 PM
  3. Is my Note 2 International?
    By machin576 in forum Verizon Galaxy Note 2
    Last Post: 11-30-2012, 05:20 PM
  4. Why is my Note 2 causing interference/static?
    By The513Sojo in forum Samsung Galaxy Note 2
    Last Post: 11-29-2012, 02:14 PM
  5. My note browser is stuck in landscape.
    By phonejunky in forum AT&T Galaxy Note
    Last Post: 05-26-2012, 07:47 PM
