will this work with the most recent phone update? I have Android Version 4.1.2
It will, the only issue with using it on the newest update is that your phone will THINK its on the older build and you'll be nagged to update. Other than that its fine on the newest fw. With that said Im hoping to have a fix up today/tmw and if u choose to use this in the meantime just apply my update when i post it and it will fix the update nag.
You download to your computer then connect your phone with usb debugging on. Make sure you have the drivers installed before you start.Sorry New to this. Do you do this download to your computer or your cell phone? Then what it's the next step?
Thanks
http://forums.androidcentral.com/report.php?p=2664372 but be warned it has not been updated to the latest firmware (md4) yet. Im working on itCan you post the link that you used to get the files for the Samsung Galaxy S3 in order to turn off the shutter sound?
THanks!
Thank you for answering thatYou download to your computer then connect your phone with usb debugging on. Make sure you have the drivers installed before you start.
Flash this one-click the same wayMy phone got an update but it failed to install. My guess is because I modified that file. So how do I revert the files without having root so I can update; or will I have to factory reset?
http://rwilco12.com/Files/Devices/S...estore/Unrooted/SPH-L900_MC2_Stock_Nodata.exe
No data wipe required.
And hang in there updates to the newest fw are coming. working on a lot of s3/n2 projects and its a tad overwhelming. I didnt forget about this tho
Any chance there will be an update on this?
I'm sorry for the delay. It has been updated to work with mc2. It is also no longer password protected. Also changed the bit.ly link to something easier to remember so non-members of the site can download as well
no this shouldn't affect auto updates. The reason that happened was due to the phone receiving an update and people continued to use this outdated fix. That problem should be solved but please, if something similar happens don't hesitate to message me for helpThanks so much! Appreciate all the hard work! Quick question. Do you know if this will effect auto updates? The last time I had difficulty getting the newest update and I had to wipe and factory reset my phone to get the latest update. Will this mod do the same thing? Will I need to flash a rom in order to get any updates? (I didn't know this last time and had to take it into a store to have them update which took them several hours). Just wanting to be prepared for next time! Thanks again for everything you do!
