1. Jamzones's Avatar
    Well just like of of the title says: How do i know if i'm still using stock rom if i used cwm to root and if not will i still be able to get ota automatically or do i have to do it manually?
    05-03-2013 10:31 PM
  2. Golfdriver97's Avatar
    Well just like of of the title says: How do i know if i'm still using stock rom if i used cmw to root and if not will i still be able to get ota automatically or do i have to do it manually?
    Gaining root access does not change the fact that you are using a stock ROM. Root access is a superuser level that the phone recognizes and allows you to do things that you could not do without it. If you want to look at the ROM, you can go to Settings>scroll down to About device. You can check root access by downloading an app called root check. And once you have root access you can no longer download OTA updates unless you can fully unroot, or some superuser apps allow a temporary unroot.
    Jamzones likes this.
    05-03-2013 11:28 PM
  3. Paul627g's Avatar
    Unless you flashed a custom ROM that you downloaded you are still running the stock ROM.
    In some situations you can still receive OTA update as long as you haven't deleted stock bloatware and system apps. Even with the custom recovery there is some workarounds to get the update.
    Regardless of the above, you will always find someone who puts up the latest OTA update in stock form so you can flash it and stay rooted
    05-03-2013 11:29 PM
  4. Jamzones's Avatar
    I flashed a cwm rom with odin do you think i'll still be able to get official ota updates from samsung and when do you think Note 2 get 4.2 jelly bean and how do i know if i'm still using stock bloatware? i'm noob i rooted my phone a month ago. (Please help i'm 10)
    Sent from my GT-N7100 using Android Central Forums
    05-04-2013 07:38 AM
  5. jdub1981's Avatar
    10 years old ?!? Really rooting just admin privileges. Even root you can still get the update just not the over the air ones. As they come out they are frequently made available for a manual update. No big deal.
    Sent from my Galaxy Note 8.0 using Tapatalk
    05-06-2013 07:35 AM
  6. msndrstood's Avatar
    10 years old... Good for you. We'll be expecting great things from you in the future.
    What?! ...I'm msndrstood.
    via Gnex
    05-06-2013 08:33 AM
  7. Skunkape60's Avatar
    You just flashed cwm recovery with Odin. That is not a Rom.
    05-14-2013 11:37 AM
  8. Jamzones's Avatar
    Ok, So... What's the verdict?
    05-22-2013 05:56 AM
  9. Jamzones's Avatar
    Can i update using kies?
    05-22-2013 05:56 AM
  10. Trees's Avatar
    What are you trying to update? If you can clarify then someone here may be able to help further.
    05-22-2013 06:56 PM
  11. Jamzones's Avatar
    Uhmm i'm waiting for 4.2.2 jellybean can i use kies when the update comes around?
    Sent from My SGN2
    05-22-2013 09:27 PM
  12. Skunkape60's Avatar
    Sent from My SGN2
    Sprint doesn't use kies. It will be pushed to your phone.
    05-23-2013 08:38 PM
  13. msndrstood's Avatar
    I'm on Sprint and my husband's GS2 is eligible for JB 4.I. 2 and it is either by Kies or in-store install, there is no OTA available for this upgrade for the GS2.
    via Gnex
    05-24-2013 08:11 PM
  14. Jamzones's Avatar
    My phone is international version
    Sent from My SGN2
    05-25-2013 07:15 AM
  1. How do I know if my root was successful?
    By rvpn12 in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 01-28-2011, 04:09 PM
  2. How do I know if my root was successful?
    Last Post: 11-14-2010, 03:13 PM
  3. How Do You Know If Nand is Unlocked
    By F22loader in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 09-19-2010, 06:02 PM
  4. how do you know if adobe flash is installed correctly?
    By weasel123 in forum Verizon Droid Incredible
    Last Post: 09-03-2010, 04:47 AM
  5. How do I know If I successfully rooted my droid?
    By REC0GN1ZE in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 08-03-2010, 08:44 AM
