Title says it all.
I bought an unlocked ATT Galaxy Note 2 and am using it on T-Mobile's network. They have the ability to do Wifi calling, but the option isn't in the settings menu to activate it.
I called T-Mobile and they said it's because it's a different company's phone so it wont be compatible.
Is there any way rooting might help this problem?
I know there are apps that allow you to do WiFi calling, but I want to use my same number and also have signal to get texts through. Help anyone?
