1. ScottMac53's Avatar
    Title says it all.
    I bought an unlocked ATT Galaxy Note 2 and am using it on T-Mobile's network. They have the ability to do Wifi calling, but the option isn't in the settings menu to activate it.
    I called T-Mobile and they said it's because it's a different company's phone so it wont be compatible.
    Is there any way rooting might help this problem?
    I know there are apps that allow you to do WiFi calling, but I want to use my same number and also have signal to get texts through. Help anyone?
    06-26-2013 11:20 PM
  2. JHBThree's Avatar
    Title says it all.
    You won't be able to. WiFi calling is built into the T-Mobile ROM and software. Even if you root, its possible that since you don't have an actual T-Mobile device the system will 'know' and won't allow it.
    Sent from my SGH-M919 using Tapatalk 2
    06-27-2013 01:03 AM
  3. ericrangel76's Avatar
    Try going to the XDA Developers forums. There's a rom called Jedi Master that has the T mobile Wifi calling feature in the rom. The rom is pretty stable. I have used Jedi XP rom that doesn't have that feature but its a really good rom.
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 4 Beta
    06-28-2013 01:47 PM
  4. ericrangel76's Avatar
    So I took the plunge and installed T-Mobile Jedi Master 14 Rom on my unlocked Att Galaxy Note2. I have my phone rooted and I'm able to make calls over Wifi. When I installed the rom, I kept the current modem and everything works fine.
    Sent from my SGH-T889 using Tapatalk 4 Beta
    07-07-2013 11:51 PM
  5. flthyrich's Avatar
    Thanks for the tip!!
    ericrangel76 likes this.
    07-16-2013 06:13 PM
  6. bobbehrooz's Avatar
    Can you get 4G/LTE on t-mobile network with an unlocked AT&T Samsung Galaxy Note 2? Based on research the AT&T Note 2 supports 1700/2100 (band 4) MHz and should work with T-Mobile’s 4G LTE network using 1700 MHz and 2100 MHz. But has anybody verified this is actually works?
    02-08-2014 01:23 PM
  7. tube517's Avatar
    Yes, you can as long as you are in a refarmed area. I get T-Mobile LTE on my $30/month prepaid plan. About 20 mbps down/15 mbps up on my unlocked AT&T Note 2 as well as my wife's unlocked AT&T Galaxy S3.
    02-08-2014 03:47 PM
  8. bobbehrooz's Avatar
    Thanks for the confirmation. Do you use the standard AT&T Note 2 ROM? I am not sure if your unlocked AT&T Note 2 is able to get on T-Mobile’s 4G and 4G LTE? I have read that T-Mobile has reallocated (refarmed) their 1900 MHz band from 2G to 4G access and if your area has been reallocated you will get 4G on T-Mobile 1900 MHz band which the AT&T Note 2 supports. Are you also able to get on T-Mobile’s 4G LTE band (1700 MHz and 2100 MHz)? The Note 2 specs say it supports these two LTE frequencies. What have you seen?
    02-08-2014 08:31 PM
  1. Three Weeks on Net10 ATT
    By Double Tap in forum Google Nexus 4
    Last Post: 02-12-2014, 03:28 AM
  2. Kid Proof Case Galaxy Note 10.1
    By Gregg Shaw in forum Samsung Galaxy Note 10.1
    Last Post: 08-18-2013, 06:08 PM
  3. [IDEA] S Voice on the LG Viper
    By thenameisnigel in forum LG Viper 4G LTE
    Last Post: 06-29-2013, 12:51 AM
  4. Texts over WIFI?
    By JohnnyFurness in forum General News & Discussion
    Last Post: 06-27-2013, 08:51 AM
  5. [VIDEO] LG Optimus G Pro on AIO Wireless (owned by AT&T)
    By chrisngrod in forum LG Optimus G Pro
    Last Post: 06-26-2013, 06:51 PM
