How do i increase Battery charge speed and reduce battery consumption
Au3110
5
I have a Galaxy Note GT N7100 [Rooted]
I am running on Project AOSP, at 1800mHz
I have used Juice Defender Ultimate, turned it to extreme and even then I had a 40% power drop while leaving it over night
Is there any setting I can change in STweaks to decrease battery consumption or even increasing charge speed.
PLEASE HELP!!!!
dancing-bass
1,022
17
I'm assuming you've done the usual tricks already (lower screen brightness, turn of LTE or HSPA+ when not needed, turn off bluetooth and GPS when not using them, lower the time your apps refresh or poll for new data, etc)
Those things alone will do a LOT. Let's say for example you use Facebook with 200 friends. Facebook app defaults to refresh every hour... that right there is a lot of data to be polling every hour. Same thing with other social media sites, and you might want to reduce the refresh time on weather apps as well.
The other thing that may play into your battery life is how many widgets you have running, and how often THOSE refresh.
Other then that I'd say throttle your CPU somewhat, and look into other ROMs to see which has the best battery life.
Sadly it comes down to balance. Lots of features and extras and apps polling for data is super convinent but hard on the battery. Turning all that stuff off makes a "smartphone" far less smart and useful, but really takes a load off of the battery.
It could also be that the battery is getting old (depending on how long you've had the device and your previous usage and charging habits)
I don't have a Note but I've got a Galaxy Nexus which has terrible battery life. All these things are stuff that I've found helps somewhat.
Au3110
5
Thanks for the reply
Well my phone is quite new
I have removed the overclocking and am using battery doctor which showed quite an improvement in my battery life but still i am not getting the required battery life
I even used cpu sleeper which turns off 3 cores when the screen is not active.
All these stuff give me the same battery life at the end of the day
What I believe is that maybe I have too many applications on my phone (I dont use them all during the day but specially during my boredom hours{WHICH IS RARE},my phone mainly has its screen off)
Can this be a reason?!
alexlam24
Banned
Oct 18, 2012
417
Have you tried uninstalling some useless apps? I know you said this before, but it is a solution. Are your camera albums synced to the cloud or something? That could be a reason
Sent from Samsung Z1 GPE on T-Mobile
MarcosVo
