I know this is really late but if your still having your problem or if anyone is having this problem
This is how i fixed Verizon Samsung Galaxy Note 2 (SCH-I605) 4.4.2
Put your phone into download mode
Open Odin
Select Ap
Point it to I605VRUFND7_I605VZWFND7_I605VRUFND7_HOME.tar.md5
Select Pit
Point it to sch-i605-16gb.pit
Make sure you have a COM port active on the top left
Have Auto Reboot, Re-Partition, Nand Erase All and F. Reset Time checked
IF YOU DO THIS YOU WILL LOSE EVERY THING ON YOUR PHONE UNLESS YOU HAVE IT BACKED UP
Press start
When this boots you will either get into android or you will get stuck at the Verizon logo
if you get stuck then go into recovery mode (you should be able to now)
In recovery mode you want to wipe data/factory reset
and then wipe cache partion
After those are both done
Reboot into the system
And you should be able to get into setup
This method has worked for me every time i have used it on my device
Files: http : / / goo.gl/zsywEh?gdriveurl
I promise these are safe i use them every other week
