1. soleil0524's Avatar
    I have a sprint galaxy note 2 lte 4g. I needed to get it to work for pageplus, so i did everything needed and got it working. I decided to try and install a new rom so i could get rid of the sprint activation screen. So i downloaded the rom and cleared cache and reset in recovery mode. Now I am stuck on the bootscreen. I tried about 15 different roms and they are all the same. Either i have a bootloop or it just sits at the bootscreen. I was told from a friend that i am probably installing roms for the wrong build, but i dont know my build. I didnt do a back up( i know that was stupid of me). So all i know is that my phone is Sph-L900 because that is what it says under the battery. If any one could help me i really would appreciate it. Like i said i tried so many roms and they installed fine via recovery but wont go to homescreen, i already searched for hours on this and nothing is working. thank you ahead of time to everyone
    09-08-2014 02:43 PM
  2. kcohen67's Avatar
    You can use Odin in download mode to reinstall your rom. You should take it back to 4.1.2 and work your way back up ( in my opinion). There is a Great 4.3 rooted stock out there with Note 3 apps...so you can keep all the great touchwiz features. Google it if your interested.
    Sent from my SPH-L900 using Tapatalk
    09-09-2014 01:35 PM
  1. Please help
    Last Post: 09-08-2014, 02:33 PM
  2. Samsung Galaxy S4 Zoom w/Straight Talk Plan...HELP PLEASE!
    By Kaylan Yount in forum Ask a Question
    Last Post: 09-08-2014, 02:30 PM
  3. need help getting my sgh i535 back and running
    Last Post: 09-08-2014, 12:31 PM
  4. help
    Last Post: 09-08-2014, 10:22 AM
