09-26-2013 03:37 PM
105 ... 2345
tools
  1. Dr. Droidberg's Avatar
    My best yet!
    This is a Verizon Note 2 with a stock battery running "Beans" ROM. Power saving mode off. Imagine what it would be like if I turned it on!
    Attached Thumbnails How is your battery life?Note 2-uploadfromtaptalk1360530279951.jpg   How is your battery life?Note 2-uploadfromtaptalk1360530308661.jpg   How is your battery life?Note 2-uploadfromtaptalk1360530327406.jpg
    02-10-2013 03:11 PM
  2. delco714's Avatar
    ^holy crap, that's insane!!
    02-11-2013 06:21 AM
  3. chaz0717's Avatar
    Just got my N2 and I am so impressed. My last phone was the G2X. it sucked so hard. Even with an extended battery (3100) I couldnt get through a whole day. Twitter, text, light browsing, all while on wifi or 4g. I unplug about 6am, and am on about 25% 12 hrs later.
    02-11-2013 09:09 PM
  4. chadderbox's Avatar
    Easily a day, sometimes a day and a half. Generally am on the phone 6-7 hours a day being in sales and have the phone linked to bluetooth all day as well. Simply amazing phone even better than the S3 which was leaps and bounds better than my last phone.
    02-11-2013 09:11 PM
  5. Droid_Evo_8's Avatar
    Simply put: If it lasts me 8hrs or longer (especially during my work week), that's more than good enough for me.
    Unlike my previous phone (which is the Nexus).
    02-11-2013 09:37 PM
  6. tristanguy's Avatar
    Is this a normal rate?
    Attached Thumbnails How is your battery life?Note 2-2013-02-26-09-50-37.png   How is your battery life?Note 2-2013-02-26-09-50-25.png   How is your battery life?Note 2-2013-02-26-09-50-14.png
    02-26-2013 01:06 PM
  7. crystinonfire's Avatar
    your mobile network signal is pretty low, so that's why you aren't getting as good of battery life as some
    02-26-2013 02:47 PM
  8. HypoDest's Avatar
    Also, your phone is constantly awake even when the screen isn't on. There is some app or setting causing a wake lock.
    This is preventing it from going to deep sleep and reduces the battery life.
    A normal rate should deliver about 7 hours of on screen time.
    Sent from my GT-N7100
    02-26-2013 02:57 PM
  9. fade2black101's Avatar
    Are most of you using 4.1.1 or 4.1.2? This seems to make quite a difference in battery usage.. (about 30% less given the different reports I have read on this)
    02-26-2013 04:37 PM
  10. tristanguy's Avatar
    Also, your phone is constantly awake emeven when the screen isn't on. There is some app or setting causing a wake lock.
    Would Skype and steam mobile be to blame for keeping it awake?
    Edit: I've closed them, but it seems it is still not going into deep sleep.
    The battery seems to be conserved a bit more after closing them, though.
    Running 4.1.1 on US Cellular SCH-R950.
    Attached Thumbnails How is your battery life?Note 2-screenshots_2013-02-26-20-45-16.png   How is your battery life?Note 2-screenshots_2013-02-26-20-45-24.png
    02-26-2013 05:41 PM
  11. crystinonfire's Avatar
    I recently updated to 4.1.2. Doesn't seem to be a 30% decrease. I've still been getting about a day and a half.
    02-26-2013 05:43 PM
  12. fade2black101's Avatar
    A lot of people seem to find they lose a couple hours of screen on time.
    02-26-2013 08:48 PM
  13. HypoDest's Avatar
    There is a partial wakelock: UsbStorageUnmounter
    This seems to be a USB OTG related bug. Tends to Wake lock when usb otg is disconnected through the shortcut on the notification screen.
    To remove the wake lock you can try restarting the phone. To prevent it in future, you can disconnect otg through the settings / storage / unmount option instead of the shortcut
    02-27-2013 01:06 AM
  14. tristanguy's Avatar
    I rebooted my note and it fixed the wakelock problem, but im still getting crappy battery life. At 85% only 3 hours 45 mins in. It's getting alot more sleep but I still have a poor signal. Battery is still dropping in airplane mode with wifi on. About an hour of screen time.
    02-27-2013 11:14 AM
  15. Lastnv's Avatar
    Usually a day.
    I browse the internet a lot and play games
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    02-27-2013 12:09 PM
  16. zmann's Avatar
    I have been streaming Sirius since 630 am plus other use durning the day and still have 50 percent, which is amazing. Doing same thing with my evo lte I would have a dead battery by now.
    Note 2, it's true, ,size is everything!
    Attached Thumbnails How is your battery life?Note 2-uploadfromtaptalk1361993033298.jpg
    02-27-2013 01:23 PM
  17. HypoDest's Avatar
    The earlier stats extrapolated gives ~5 hours total screen time.
    15% drop for ~1 hour screen time gives 6.7 hours which is pretty reasonable since the ballpark target is about 7 hours.
    02-27-2013 01:24 PM
  18. Double0EK's Avatar
    I get great battery and screen time. Ranges anywhere from 19-26 hrs and anywhere from 6-8 hrs screen time. It all depends on how I use my phone of course.
    02-27-2013 01:50 PM
  19. GadgetgirL76's Avatar
    This is my battery life now after installing Go....
    sent from my AT&T GN2
    Attached Thumbnails How is your battery life?Note 2-uploadfromtaptalk1361995706196.jpg   How is your battery life?Note 2-uploadfromtaptalk1361995761516.jpg
    02-27-2013 02:10 PM
  20. OC Nut's Avatar
    This seems fine, actually. My estimate, which works pretty well for my N2, is about 12%/hour of screen time + 0.5%/hour of being on, so at exactly 1 hour of screen time with 3:45 of on time, I'd expect use of just under 14%. Use of the phone as a phone will also drain it a little bit.
    02-27-2013 05:43 PM
  21. fade2black101's Avatar
    Hi
    Usually people mistakingly post battery time without the screen on time, you've done the opposite
    While over 5 hours screen time is great for a normal phone, I used to be able to get 8 hours or more before I switched to 4.1.2.
    02-27-2013 06:17 PM
  22. HypoDest's Avatar
    This is what I'm getting with 4.1.2 with my typical days use.
    Seems pretty good, and its close to 4.1.1 figures
    02-27-2013 06:31 PM
  23. fade2black101's Avatar
    Decent times. . And excellent compared to other phones.
    I just find that the android system shouldnt be a few percent lower than the screen time. I always found before the update and on previous phones that the screen woukd be closer to 100% than 50 and the android system and os would barely feature on the list.
    Sinilarily ive noticed you turned wifi (and data too I assume) for a long period of time.
    Not sure if it's just me, but I've noticed that wifi seems to drain a lot more battery than it should, whereas I would get little to no drain with it on previous phones or 4.1.1 where this will drain a couple percent every hour while idle.
    02-28-2013 04:17 PM
  24. iso99's Avatar
    hello guys,
    is it normal for the upper portion of the note2 to get warm/hot when using wifi/mobile data for at least 2 hours?
    02-28-2013 08:09 PM
  25. sereney7's Avatar
    My phone can last for 7 hours only.. that is troublesome for me sometime.. anyone can help me?
    Attached Thumbnails How is your battery life?Note 2-screenshot_2013-08-01-21-25-19.png
    08-01-2013 08:36 AM
105 ... 2345
  1. How is your battery life?
    By Ohleo in forum Droid RAZR HD
    Last Post: 10-22-2012, 09:24 AM
  2. How is your battery life with the LTE service
    By cert15z in forum HTC EVO 4G LTE
    Last Post: 07-18-2012, 04:13 PM
  3. How is your Charge setup and how is your battery life?
    By ncbryan in forum Verizon Droid Charge
    Last Post: 05-19-2011, 09:38 PM
  4. How good is your Battery Life?
    By chardog in forum LG Optimus S
    Last Post: 03-03-2011, 03:34 PM
  5. thinking about getting a droid, how is the battery life?
    By matt9484 in forum Motorola Droid
    Last Post: 05-29-2010, 08:01 PM
