01-08-2018 04:40 PM
99 1234
tools
  1. james27007's Avatar
    Turn Off 3G & Wifi. It will save lot
    I disagree, I leave WiFi, Bluetooth and GPS on 24/7 and get on average 22 - 26 hours on one charge. And it is about the same if not less if I turn them off. I think everyone should read the post here:
    androidforums.com/samsung-galaxy-s3/618583-truth-about-your-battery.html
    12-07-2012 04:06 PM
  2. Hikmat abdoollayev's Avatar
    Or a good app that can track which apps are causing the battery drain!
    Thanks!
    Maybe, your phone has a problem with wakelocks, Google "android wakelock" for more details.
    I would recommend you "Wakelock detector" app, it is all about wakelocks,
    03-14-2013 09:41 PM
  3. jdub1981's Avatar
    I shut virtually everything before going to bed last night and still lost 20% approximately. Maybe need to turn off wifi before bed? Is this issue with all carriers? I'm using at&t. This is not a big deal, more of an annoyance because during the day with use the battery life is great so why does it drain so much overnight!
    Attachment 49462
    Sent from the unparalleled Note 2
    Something in the OS possibly an app is the issue here. Your screen should almost always use the most power. Anything that uses more power than the screen is probably your culprit. I dont know what this wake lock thing is, but I have never had that problem in the 4 months ive owned the phone. I consistently get 24 hours use with maybe 9-10 hours of screen on time. Your best bet is to use a battery monitor of some type so you can narrow down the problem.
    03-14-2013 09:49 PM
  4. htguy's Avatar
    What software version are you on? 4.1.2? If yes have you noticed the battery drain since upgrading?
    03-14-2013 09:54 PM
  5. SDHarleydad's Avatar
    Im losing about 3-4% overnight
    Size does matter! -☆SGN2☆
    03-14-2013 11:25 PM
  6. serpico's Avatar
    I've noticed this on mine since the last update. It was less than 5% running on the previous os. Is Multi View to blame? No matter what I do it's losing about 20% overnight too.
    03-14-2013 11:30 PM
  7. Droid_Evo_8's Avatar
    For those of you who has task killers and juice defenders, DELETE it. It's not helping with the battery losses, but instead, it's making it worst by not putting it to Deep Sleep.
    Buy and install Deep Sleep Battery Saver Pro. Puts your phone into deep sleep with various settings. (More options if you root your phone, I did). AWESOME app. You're welcome.
    03-15-2013 02:30 AM
  8. zmann's Avatar
    I don't understand the point, help me please. What is the point of having a smartphone that can do all these amazing things if you just want to carry around a paperweight in your pocket. Just buy a spare battery. The back cover is by far the easiest I ever had as far as taking off. I actually have 5 battery's.. I would say I run into a situation about twice a week where I need to swap my battery out.. It takes 10 seconds to change the battery (yes I timed myself lol) and phone reboots in less then 20 seconds. The point Is i can enjoy my note 2 the way it is ment to be enjoyed,, not shutting down all the wonderful features of a smartphone. This is just my opinion and my suggestion and I am in no way saying this in a hostile tone so please, nobody jump down my throat. Lol
    Note 2, it's true, ,size is everything!
    03-15-2013 06:24 AM
  9. jneusch's Avatar
    I don't have a spare battery, but i am near a power source enough to plug in when necessary. I couldn't agree with you more. All the posts about turning off GPS, BT, other location services, push email, etc, etc. These are all benefits and the price to having a smart phone. Enjoy it for all it does!
    Sent from my SCH-I605 using Android Central Forums
    zmann likes this.
    03-15-2013 08:44 AM
  10. intheb0x's Avatar
    Wow, that horrible drain.
    Android os has NEVER been number 1 on my device in the list, here how my phone looks now.
    Granted it's only been off the charger for 3 hrs I have screens of long term I'll post too . you definitely have something wrong here.
    Honestly, I'd start fresh and reload the OS
    I never loose more than a couple percent over night, this phones battery is incredible, i never had a phone that lasted so long.
    Sent from my ATT Note 2!
    03-15-2013 09:06 AM
  11. intheb0x's Avatar
    And honestly I leave wifi, gps data and everything on and never loose more than a few percent.
    I'm stock not rooted.
    zmann likes this.
    03-15-2013 09:09 AM
  12. jdub1981's Avatar
    Im rommed but dont have a custom kernel that affects battery life. Your pics look just like mine as far as apps running. Other than gps I never turn off wifi or bluetooth
    Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
    03-15-2013 09:54 AM
  13. tirith's Avatar
    I turn off Wi-Fi when I leave my house.
    Never have bt on until I replace the Bluetooth I broke.
    Location always on.
    Moderate to heavy usage.
    Brightness around 15-20%
    Lasts all day
    ~swyped from my galaxy note 2 on the now network
    03-15-2013 11:35 AM
  14. Almeuit's Avatar
    Attachment 49462
    Your maps app seems to be the culprit. The OS is high because your maps is causing you system to stay awake.. If you sleeping maps shouldn't be doing anything.
    Try clearing the cache on maps and ensure its close and not using up cpu while you sleep.
    Sent from my Sprint S3 using AC forums.
    intheb0x likes this.
    03-15-2013 01:08 PM
  15. zmann's Avatar
    Great observation. May have a app that is causing that in the background.
    03-15-2013 05:03 PM
  16. Almeuit's Avatar
    Yeah I am not sure if you guys had a update recently but I finally got jumped to 4.1.2 and I'd say the first couple of nights the maps app kept doing this to my S3 as well and it caused the phone to wake up a ton at night (looked like every 5 min) so my phones battery would start to drain a lot more than it should over night.. So that caught my eye.
    I just cleared map cache. Force stopped it in the application manager and rebooted. It hasn't done it sense.
    03-15-2013 08:02 PM
  17. intheb0x's Avatar
    Here's how mine looks now, I'm still stock because I clearly don't see what advantage I'd have roming when the OS and kernel combo stock is so well tweaked.
    I also always have auto brightness on.
    03-16-2013 12:55 AM
  18. Onemoa's Avatar
    I'm on T-Mobile and I lose about 10% battery overnight. I keep wifi on. If I turn wifi off I lose more like 15% to 20% but that's because I have a bad 4g single in my house.
    But I'm still running 4.1.1 we didn't get 4.1.2 yet. I just can't wait for 4.2.2 that will bring battery life up even more. I just hope 4.2.2 comes soon. Then again in happy with the way my phone is running now. But more Battery life is always better.
    Sent from my SGH-T889 using Tapatalk 2
    03-19-2013 04:54 AM
  19. ecs180's Avatar
    i posted another thread called "not so known battery saving tips"...should clear all your issues up
    as someone posted earlier...if you have bad signal that will drain battery big time also
    Phoneguy108 likes this.
    03-19-2013 08:32 AM
  20. Onemoa's Avatar
    I just got 4.1.2 and now maps is top battery drain when I look in settings. What is the setting always report from this device? Is that something I need on in order for Google now to work correctly?
    Everything was fine until 4.1.2, I'm not saying it's not wroth the update
    03-23-2013 02:21 AM
  21. Jude526's Avatar
    Bad sgnak can eat battery use. I make sure wifi is off if not using. I don'thace wifi and if using public I make sure off when not using. I don't keep Bluetooth on all the time. It uses battery too.
    I get awesomeness from battery use. I also have the battery power saver on. It doesn't harm anything. Just keeps screen brightness low. Maintains CPU. Phone functions just fine. No faults
    Sent from my Samsung Galaxy Note2
    03-25-2013 02:38 PM
  22. Jude526's Avatar
    Signal ++++
    03-25-2013 02:38 PM
  23. universeand's Avatar
    I have 4 batteries and use 3, thanks to the publicly floating 50% off codes for Samsung (even got 2 of them with the chargers which work great.) Whenever a battery drains I just swap it for a juiced one. Never plug in the device now. Definitely feel freer not having to stay near the AC.
    03-25-2013 08:29 PM
  24. rhaneyjr's Avatar
    Clean ROM with the Perseus kernel. You will see the difference
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    03-30-2013 07:48 PM
  25. andy a's Avatar
    Errrr do what with what!!!!!!
    03-30-2013 08:04 PM
99 1234
  1. Sudden battery loss after reboot
    By adlebo in forum Sprint Epic 4G
    Last Post: 10-04-2018, 03:41 AM
  2. Does Wifi Stay On with Phone Off? Battery Loss Overnight
    By kmully in forum Verizon Droid Incredible
    Last Post: 11-24-2010, 08:52 AM
  3. Smart battery loss of data upon awake.
    By rjdangerous in forum Motorola Droid X
    Last Post: 09-17-2010, 11:42 AM
  4. Answer to immediate battery loss?
    By slinky317 in forum Verizon Droid Incredible
    Last Post: 06-10-2010, 09:46 PM
  5. My battery drained overnight
    By pbrennan42 in forum General Help and How To
    Last Post: 01-02-2010, 02:30 PM
