james27007
Download and install an app called GSam Battery Moniter it not only tells you what is using your battery but even more detail on what apps are using your battery.
Turn Off 3G & Wifi. It will save lot
Maybe, your phone has a problem with wakelocks, Google "android wakelock" for more details.Or a good app that can track which apps are causing the battery drain!
Thanks!
I shut virtually everything before going to bed last night and still lost 20% approximately. Maybe need to turn off wifi before bed? Is this issue with all carriers? I'm using at&t. This is not a big deal, more of an annoyance because during the day with use the battery life is great so why does it drain so much overnight!
Sent from the unparalleled Note 2
For those of you who has task killers and juice defenders, DELETE it. It's not helping with the battery losses, but instead, it's making it worst by not putting it to Deep Sleep.
Buy and install Deep Sleep Battery Saver Pro. Puts your phone into deep sleep with various settings. (More options if you root your phone, I did). AWESOME app. You're welcome.
I don't understand the point, help me please. What is the point of having a smartphone that can do all these amazing things if you just want to carry around a paperweight in your pocket. Just buy a spare battery. The back cover is by far the easiest I ever had as far as taking off. I actually have 5 battery's.. I would say I run into a situation about twice a week where I need to swap my battery out.. It takes 10 seconds to change the battery (yes I timed myself lol) and phone reboots in less then 20 seconds. The point Is i can enjoy my note 2 the way it is ment to be enjoyed,, not shutting down all the wonderful features of a smartphone. This is just my opinion and my suggestion and I am in no way saying this in a hostile tone so please, nobody jump down my throat. Lol
Note 2, it's true, ,size is everything!
And honestly I leave wifi, gps data and everything on and never loose more than a few percent.
I'm stock not rooted.
Sent from my ATT Note 2!
Your maps app seems to be the culprit. The OS is high because your maps is causing you system to stay awake.. If you sleeping maps shouldn't be doing anything.
Try clearing the cache on maps and ensure its close and not using up cpu while you sleep.
Sent from my Sprint S3 using AC forums.
