1. Boba7523's Avatar
    Hi guys, I am using Go Launcher right now and have customized my home screen to the way I like it and removing the stock Go Launcher dock icons and adding my own from my list of apps. It all works, but when I restart my phone, the dock customization I did was not saved; however, the rest of the customization was. Is this a known bug?
    12-15-2012 12:29 AM
  2. Mweuch's Avatar
    I am using Go Launcher and have no problem at all. Try reinstalling it n see how it works. Thanks
    Boba7523 likes this.
    12-15-2012 03:53 AM
  3. Glockster_JPN's Avatar
    I have been experiencing the same, and just emailed the developer if there is any fix to it.
    I will keep you posted on this when I hear from them.
    12-08-2013 03:25 AM
  4. richard hodge's Avatar
    I also had this problem, my icons were reseting whenever I turned off the phone and the backups were wrong but it got fixed pretty fast after I sent a report
    Sent from my GT-N7100 using Tapatalk
    12-08-2013 02:18 PM
  1. Weird issue with seidio car dock
    By I.R.R.V. in forum EVO Accessories
    Last Post: 08-21-2011, 09:12 PM
  2. Widget Launch problems with Go Launcher
    By stacyadell in forum Android Apps
    Last Post: 03-16-2011, 02:23 PM
  3. Tw launcher dock customizing?
    By jerseykat1 in forum Sprint Epic 4G
    Last Post: 02-22-2011, 11:38 AM
  4. Help with Go Launcher
    By dwalker in forum Android Apps
    Last Post: 01-18-2011, 07:44 PM
  5. Replies: 2
    Last Post: 07-19-2010, 12:44 AM
