1. wburleson's Avatar
    Hi, I'm looking for an app that will automatically connect to my home Wifi when I'm at home. Then disconnect Wifi when I leave home and turn on bluetooth. Can any one give me the name of an app
    Thanks
    12-18-2012 04:34 PM
  2. jneusch's Avatar
    Locale should do the trick. https://play.google.com/store/apps/d...yfouram.locale
    It's not a free app, but it should work how you want it to and does not require root. I also use it with Astrid for location based reminders. For example, I set up Costco in Locale and created a list called Costco in Astrid. Whenever I arrive at Costco it reminds me of the things in my list. Very similar to Siri in that respect, but it does a lot more too.
    If you set up your Default to WiFi "off" and set up your Home to WiFi "on" it will do what you want. Anything above Default will override default settings.
    Good luck!
    12-18-2012 05:00 PM
  3. Rangie's Avatar
    Tasker
    Sent from my SPH-L900 using Tapatalk 2
    12-18-2012 05:55 PM
  4. jneusch's Avatar
    Tasker
    Agreed, but I believe it requires root. Some cannot or choose not to root for various reasons.
    12-18-2012 06:55 PM
  1. Need some help with ics and Aol
    By mjacob2448 in forum Motorola Xoom 2
    Last Post: 08-28-2012, 02:22 PM
  2. Need help with website and messaging system
    By pstellato73 in forum Toshiba Thrive
    Last Post: 09-06-2011, 03:08 PM
  3. Need some help with clockworkmod and flashing rom
    By stlsports in forum Sprint Nexus S 4G Rooting, ROMs, and Hacks
    Last Post: 08-14-2011, 12:00 PM
  4. need some help with the radio and PRL's
    By jonathanlc2005 in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-01-2011, 09:44 PM
  5. Need help with Android and VOIP
    By tmettler5 in forum Android Apps
    Last Post: 01-30-2011, 08:29 AM
