1. 1_Jade's Avatar
    I only got my Note 2 for barely a week and realised that the power button is a little loose (especially on the upper part, if you look at it vertically). I did some research (Um... Google), it seems to be a common problem with Samsung devices, like the SIII... ?
    I have no problem with it and is 100% functional (I think/hope). I am a little concern if it might falls off or stop working one day soon.
    What do you guys think? Should I bring it back... or something... Maybe I am being over sensitive.
    Thanks!
    12-30-2012 07:34 PM
  2. DroidXcon's Avatar
    Thanks!
    take it back. you paid S#!^ ton of money for it, it should be perfect out of the box
    Johnly likes this.
    12-30-2012 07:37 PM
  3. jdub1981's Avatar
    The button has a curve on the inside so that it can fit into the case without sliding all the way through and out the other side. The body of the phone holds the actual button for power. The piece you touch merely floats on top. Unless you break the inside of the button you should be fine. Mine is a little loose as well.
    Having come from iphones I can now appreciate the design quality of thise products. If iphone had a 5.5" screen I probably have never left.
    12-30-2012 07:42 PM
  4. 1_Jade's Avatar
    I was two steps away to do so. The only thing holding me back was the fact I might have to deal with the sales representative. Ha.
    Um... I see and yes, the upper part was kind of floating when I touch it. Well I will try not to break it lol if I do, I hope they can fix it.
    Thanks guys!
    12-30-2012 07:57 PM
  5. laststop311's Avatar
    I know what you mean. I wouldn't say it's totally loose. It's just kind of how their buttons are. You should have no issues from it for the life of your phone.
    12-31-2012 02:28 AM
  1. Is the power button a problem?
    By evilhugbear in forum Sprint Nexus S 4G
    Last Post: 07-21-2011, 01:51 PM
  2. I think i have a problem with the capitave buttons?
    By anoiel1220 in forum HTC EVO 3D
    Last Post: 07-16-2011, 05:26 PM
  3. real problem with the soft keys ?
    By guigui357 in forum Google / HTC Nexus One
    Last Post: 01-19-2010, 11:19 AM
  4. Problem with the backgrounds app
    By Theodore55 in forum Motorola Droid
    Last Post: 12-30-2009, 06:16 PM
  5. Problem with the Privacy screen from Verizon
    By bmderuosi in forum Motorola Droid
    Last Post: 11-06-2009, 09:35 PM
