1. Jomari Co's Avatar
    Just bought the note 2 little over a month ago,so far so good,hmm i'm just a little concerned with the rate of battery drainage i have.I took it of the charge at 11 pm 88% got back to it at 12 pm drained by 6%.Right now from 82% with just using chrome battery drained 74% in just 40mins.Is this normal?. ohw btw I can see that the game wild blood i have uses 20% battery according to settings,could this be the source of the problem?
    01-10-2013 10:36 PM
  2. Jomari Co's Avatar
    Correction, battery drained and only 74% remained.not 74 % was the amount drained,sorry i'm posting this from my phone
    01-10-2013 11:04 PM
  3. jdub1981's Avatar
    Graphically intensive games ramp up the processor and drain battery. It very possible this is your issue. I have learned quickly that with android you have to be proactive and monitor what apps you have running and how much battery apps actually use.
    Sent via Tapatalk
    01-10-2013 11:37 PM
  4. mxb54587's Avatar
    Make sure you do the following:
    -Disable the bloat wear depending on your phone.
    -Turn off any apps that constantly connect to the web to get information.
    -Lower the refresh time of your widgets to 30 minutes or latter
    -turn off mutli window, gps, bluetooth etc when not using them.
    I have 2 extra batteries, but most of the time I find that I can get threw at least the work day and the evening with out having to charge my phone.
    ImmaGhost likes this.
    01-11-2013 08:43 AM
  5. andy a's Avatar
    where do I go to turn off all the stuff you mentioned as I can't see the one for widget refresh and the others?
    01-11-2013 12:07 PM
  6. tirith's Avatar
    Widget refresh are in the settings for the app or the widget, like weather, you have to go into weather and go to settings there.
    The gps, multi window, etc would be found at the top of the notification bar. Or in settings.
    Sent from my G-Note 2
    01-11-2013 12:36 PM
  1. How is the battery life for the Vivid?
    By Deflord in forum HTC Vivid
    Last Post: 11-17-2012, 03:42 PM
  2. Is this typical battery life for the Galaxy Nexus?
    By Atranox in forum Verizon Galaxy Nexus
    Last Post: 02-18-2012, 07:38 AM
  3. Is this typical battery life for an X?
    By 0pusX in forum Motorola Droid X
    Last Post: 03-25-2011, 10:15 PM
  4. Is this normal battery life ?
    By OrderedtheEvo in forum HTC EVO 4G
    Last Post: 07-08-2010, 07:04 PM
  5. Anticipating BAD battery life for the Evo
    By c3PreO in forum HTC EVO 4G
    Last Post: 06-02-2010, 06:23 PM
