SD card problems: incl reading on PC
tonylinde
15
In my Galaxy Note 2 (from T-Mobile UK) I have a Sandisk 32Gb SDHC card. It worked fine for the first couple of months but just recently has begun saying that the card has been removed then asking if I want to reformat it etc . Just as others have noted here.
However, when I got that message, I took a pic with the phone then used the 'My Files' app to look at /storage/sdcard0/DCIM/Camera and the pic was there! Just saw on another thread that sdcard0 is the internal memory. Doh!
I saw that one recommendation was to copy stuff off the card then reformat to FAT32 and add the files/folders back. Unfortunately, I cannot get either my PC or Macbook to recognise the card. I tried using an Integral USB multi-card reader to load the card to the PC, also a microSD adapter directly into the PC's SD slot. Neither worked (though the multi-card reader brought up errors about a system reserved drive K!). Do I need a special driver to read the Samsung formatted card?
Anyone got any ideas?
Thanks,
Tony.
MobileMadness002
159
If your computer fails to read it using an external card reader, you can be pretty safe presuming the card is garbage now. If you cannot format the drive directly in the computer, then replace it. Personally I use a a Kingston 32 GB SDHC and have yet to experience any issues in my BlackBerry nor in my S3.
PS. No, no special drivers required to read your usb card in the computer.
tonylinde
15
Thanks for that. Just ordered a Kingston 32Gb Class 4 from Amazon. Guess I should format it with FAT32 in the PC before loading into the phone.
(BTW, Amazon offered to take the duff card back, even after 3 months, but I finally decided that if I couldn't wipe the card, I didn't really want it out in the wild.)
t.
aquafusiondane
119
Mmmm that the same card that my friend is using for her Sprint Note 2. She complaining sometime it did just that too. I thought something must be wrong with the phone. But since you guys have the same sd card, apparently it the sd card. I am using AmazonBasics 16gb class 10 on my phone and never have any problem with it
Sent from my T-Mobile Samsung Galaxy Note 2 on Tapatalk 2
guylenn49
