1. MichelleX's Avatar
    I keep setting my Note 2 to use a particular application for opening documents or webpages, etc, and to stay on while plugged in (in developer options)... and it just keeps forgetting them every time I switch off. I love the phone and this is my only niggle with it.
    Is there a way of making it remember all the settings I choose, so I don't have to do it every day?
    Thanks
    M
    01-23-2013 04:02 PM
  2. 1812dave's Avatar
    are u setting the apps to "Always"?
    01-23-2013 04:03 PM
  3. bigoldthor's Avatar
    +1. When you choose which app to use for a particular task, choose "Always" instead of "Just Once" and it will remember your preference. If you ever decide to change that, you can go into the app settings and clear defaults.
    01-23-2013 07:26 PM
  4. MichelleX's Avatar
    Yes, I'm setting the apps to always, but they're still forgetting my choice. When I switch the phone back on, it's as though I've never made a choice.
    - - - Updated - - -
    01-24-2013 02:17 AM
  5. 1812dave's Avatar
    A reset may fix it
    Sent from Note 2
    01-24-2013 08:55 AM
  1. How can I transfer videos and photos from my note 2 to my ipad?
    By Andyvalver in forum General Help and How To
    Last Post: 11-10-2015, 10:25 PM
  2. Why does my EVO keep resetting my Email settings?
    By Lord Vader in forum HTC EVO 4G
    Last Post: 11-18-2012, 10:11 PM
  3. Need some help with a few sound setting in my Note II
    By GirlWithTea in forum General Help and How To
    Last Post: 11-16-2012, 11:52 AM
  4. GoSms keeps forgetting my customized theme.
    By TonyLibations in forum HTC EVO 4G LTE
    Last Post: 07-22-2012, 08:11 PM
  5. can i install skyraider on my incredible and keep all my contacts/apps/settings?
    By mags87 in forum Software Development and Hacking
    Last Post: 08-19-2010, 10:48 AM
