09-10-2013 03:35 AM
66 123
tools
  1. Andyvalver's Avatar
    I charge mine each night regardless of what battery is left but last night I never charged it and here is what im at...
    Ill post one later when its at the last 5%
    Sent from my GT-N7100 using Android Central Forums
    Attached Thumbnails My Samsung Galaxy Note 2 Battery Life-uploadfromtaptalk1359379587686.jpg
    01-28-2013 07:26 AM
  2. Andyvalver's Avatar
    10% left..
    Attached Thumbnails My Samsung Galaxy Note 2 Battery Life-uploadfromtaptalk1359400440781.jpg
    01-28-2013 01:14 PM
  3. Droid_Evo_8's Avatar
    And what's the screen time?
    01-28-2013 01:42 PM
  4. Andyvalver's Avatar
    I dont know. Where do I find that? Ive not been using it like mad. Just like normal. Its still going now. The main thing for me is that it will last a full day if I do decide to hammer it. My iphone used to die about 8pm the same day
    01-28-2013 02:43 PM
  5. vietalogy's Avatar
    Tap on screen time.
    Sent from my Nexus 4
    01-28-2013 02:49 PM
  6. Andyvalver's Avatar
    It was 6 hours 12 mins.
    Cheers. Never knew you could go into each bit
    01-28-2013 03:51 PM
  7. Elai012488's Avatar
    Hmmm, my note 2 was fully charged before I sleep and woke up 8hrs after with a 75% battery. I have no idea what's happening. I downloaded the cpu thingy and it didn't go in deep sleep blah blah. Deleted all the things i thought could contribute to the battery drain but to no avail. i even disabled the sensors etc. using android 4.1.1.Please help me.
    02-04-2013 05:54 AM
  8. Ahmed Hanafy's Avatar
    Can anybody help me pIz with this problem I tried everything With MY phone (Samsung galaxy Note 2) but it didn't work I had charged My phone fully and I switched off the Wi-fi , mobile network (3G) , Gprs , Sync , Bluetooth & switched the brightness to the lowest possible value , also I don't use live wallpapers & I switched on the power saving mode yet the battery vanishes so fast & here is a Pic after only 4hrs usage and its 52% what else can I do with this battery to work properly like others ?? and also 61% after about 7hrs without even using it can anybody
    help me plz ??
    03-03-2013 04:11 PM
  9. MichaelMar42's Avatar
    My note 2 also have the same problem factory reset solve this issue.
    03-23-2013 03:11 PM
  10. Todor Rusinov's Avatar
    Yes .. factory reset is the issue
    my Samsung galaxy S got the same problem, display battery usage 40-50% with minimal brightnes and 10 sec screen time
    04-11-2013 07:12 PM
  11. erkwin's Avatar
    So I've been trying all sorts of the things that people were telling me to do yet to no avail. I did however figure how to save tons of life by my own means even with bad signal and made an account just to share it. I went to settings, display, then notification panel and pulled the 'mobile data' tab to active and turn it off and onwhen not in use.
    Its same idea as not syncing email but to the point of everything that requires data.
    I only lose about 3 percent after 8 hrs of sleep which use to be 20 to 25. Also if you're at home best to turn off data and leave wifi on anyway no need to keep both on to suck all the juice. Hope this helped.
    04-18-2013 11:44 AM
  12. JasW's Avatar
    If you're connected to wifi, data simply won't be used, so I don't believe there is any battery life to be gained.
    04-18-2013 11:54 AM
  13. Manuel La Bor's Avatar
    These were taken after ~13 1/2 hours of battery. This is my average usage pattern.
    Sent from my SAMSUNG-SGH-I317 using Android Central Forums
    04-19-2013 11:15 PM
  14. erkwin's Avatar
    Even if your connected to wifi, battery is still being consumed with the lte trying to find a signal I believe.
    Here's a screenshot at 50 percent with about 3 of the 4 hrs used at half brightness reading ebooks and playing family feud. the other hour is used throughout the day checking email and sport scores. I turned on wifi or data depending if I am home or not. It works out to be 90 min per 1 percent if I leave it fully idle.
    Attached Thumbnails My Samsung Galaxy Note 2 Battery Life-screenshot_2013-04-19-20-17-00.png   My Samsung Galaxy Note 2 Battery Life-screenshot_2013-04-19-20-17-14.png
    04-20-2013 12:01 AM
  15. mercdizzle's Avatar
    Why in the world are you using a task killer app?
    04-26-2013 09:38 PM
  16. Manuel La Bor's Avatar
    Why not?
    04-27-2013 05:38 PM
  17. SDHarleydad's Avatar
    I'm having a good day with the battery.
    Size does matter! -☆SGN2☆
    Attached Thumbnails My Samsung Galaxy Note 2 Battery Life-uploadfromtaptalk1367189989804.jpg
    04-28-2013 06:00 PM
  18. fade2black101's Avatar
    Please get into the habit of posting the screen on time too
    04-28-2013 06:25 PM
  19. sejgiul's Avatar
    How's this for battery life? Better than I've had with any phone tbh..
    Attached Thumbnails My Samsung Galaxy Note 2 Battery Life-uploadfromtaptalk1367694415852.jpg   My Samsung Galaxy Note 2 Battery Life-uploadfromtaptalk1367694432420.jpg
    05-04-2013 02:07 PM
  20. fade2black101's Avatar
    Not great tbh..
    On the original 4.1.1 firmware I was getting between 9-10 hours screen on time and a little over a day battery life.
    05-04-2013 08:01 PM
  21. sejgiul's Avatar
    Wow! How much are you getting now?
    05-05-2013 03:22 AM
  22. kkapoorr's Avatar
    Sent from my Note II
    05-05-2013 04:02 AM
  23. fade2black101's Avatar
    Nowhere near as much. About a day, but it doesn't seem to matter if it is 3 hours screen on time or 6 hours. It drains when idle unfortunately.
    I have the LTE model though, which I think drains faster in general. Also, I have strong reason to believe that leaving wifi on also drains the battery. Inexplicably, and unlike any phone I've ever had, it actually saves battery to switch to 3G instead of wifi when the screen is off.
    Methinks someone has made a mess of the 4.1.2 updates so far.
    05-06-2013 05:11 AM
  24. sejgiul's Avatar
    Is there any point in resetting to factory settings? Have you tried to see if it makes a difference?
    05-06-2013 05:19 AM
  25. sejgiul's Avatar
    I decided to reset regardless. Will report on results
    05-06-2013 06:47 AM
66 123
  1. Standby is killing my Samsung Galaxy Precedent's battery
    By cryandwriteasong in forum General Help and How To
    Last Post: 09-29-2013, 01:24 AM
  2. how could i put my samsung galaxy note 2 as a hotspot
    By Stephen Guzman in forum Sprint Galaxy Note 2
    Last Post: 09-10-2013, 07:11 AM
  3. Samsung Galaxy S Battery Life Help
    By Plinkfoyd in forum General Help and How To
    Last Post: 05-17-2013, 08:05 PM
  4. Replies: 12
    Last Post: 11-14-2012, 08:27 PM
  5. Lost All my camera photos on samsung galaxy note Running ICS OS
    By bahaazein in forum New to the Forums? Introduce Yourself Here!
    Last Post: 09-19-2012, 01:50 PM
