Android System and Android OS draining my battery since updating to 4.1.2
Dekz
21
Bone stock, not rooted or rommed.
My battery life used to be phenomenal. I would check at the end of basically every day and averaged 4-8 hours of actual Screen On time. The Screen would account for 40-55% of the usage, followed by all of the apps that I had used that day. Android System and Android OS would be pretty far down on the list.
Now that I have 4.1.2, I'm lucky to hit 3 hours of Screen On time. And now Screen, Android System, and Android OS are accounting for 20% EACH.
I haven't changed any settings or the way that I used the phone. The only thing that has changed is the update.
Is anybody else experiencing this?
1812dave
3,133
35
you could try running in safe mode or do a reset. it's either an app issue or the phone needs a reset. good luck.
alamarco
192
Use Bettery Battery Stats. It will help you pinpoint what process exactly is causing the drain instead of just generalize it to the OS.
Puiman
