1. universeand's Avatar
    For such a luxurious phone the calculator should have Memory Store (MS), Memory Plus & Memory Recall functions. Both for the simple and especially the scientific modes. I find the lack a surprising oversight by Sammy.
    02-22-2013 08:21 PM
  2. 1812dave's Avatar
    ah, can't you find a suitable calculator with those features in the Play Store??? for free?
    universeand likes this.
    02-23-2013 06:22 PM
  3. msavic6's Avatar
    Try RealCalc, it is my preferred calculator.
    Sent from my MZ604 using Tapatalk HD
    02-24-2013 12:56 AM
  4. WHaydock's Avatar
    That's Android, nothing to do with Samsung, ask Google rather
    WarrenH
    02-24-2013 05:12 AM
  5. donec's Avatar
    I use "AirCalc" when I plan on doing a quick calculation or need another app running at the same time because it is a floating app. When I am doing more and may need memory I use "Easy Calculator" It not only has memory but it has several memories (don't know it may have unlimited memories) meaning you can save a number to memory and then same a different number to memory and recall which ever one you want when ever you want it. then when I need a formula I switch to "MyScript Calculator" it is a hand written calculator. So you can write with the s-pen like on paper your formula and it gives you the answer.
    https://play.google.com/store/apps/d...=search_result
    https://play.google.com/store/apps/d...Z0LmNhbGMiXQ..
    02-24-2013 12:21 PM
  1. Full calendar widget on Verizon note 2 missing?
    By htc evo 4g in forum Verizon Galaxy Note 2
    Last Post: 01-23-2013, 10:30 PM
  2. Missing play store, won't install, and won't update.
    By Hogwit in forum Verizon Droid Charge
    Last Post: 12-27-2012, 11:41 PM
  3. Missed Calls.. ?? Any ideas before I go to the VZW Store?
    By bwhite757 in forum Motorola Droid
    Last Post: 07-30-2011, 11:12 AM
  4. Just finished Rooting and now Apps are missing from App Store
    By walkerwade in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 07-08-2010, 03:45 AM
  5. Best Internal Mem + SD Music Player?
    By titaniumwombat in forum Verizon Droid Incredible
    Last Post: 06-21-2010, 07:50 PM
