I bought a GN2 in December 2012. After the initial happiness, which lasted a full month, I started having problems with my shiny, new Note 2. It all started when I decided to upgrade to a new firmware 4.1.2 from the original 4.1.1. After the upgrade I noticed that suddenly my Wi-Fi speeds went down a great deal. I was using Speedtest for some time, so I could compare the downlink and uplink speed numbers before and after the upgrade. My downlink speeds went down from 15-25 Mbps to sometimes as low as 0.100 Mbps (!). Strangely enough, my uplink speeds seemed to be in the same range as before, i.e. around 3-5 Mbps. Of course, initially, I suspected everything but the GN2. I checked and re-checked the whole Wi-Fi setup on my wireless network, which by the way, uses an Apple Airport Extreme router. Soon I discovered that my other devices, mostly Apple iPads, when tested using Speedtest and the same server, get much higher downlink speed numbers, reaching more than 30 Mbps. Does anybody has the same problem with Wi-Fi downlink speeds after the firmware upgrades? Or, is it a hardware related problem requiring going to the store and requesting a new GN2?
